SIP
Re: SIP
так откуда они тогда беруться у вас?
с чего вобще взято предположение из стартового поста?
sip set debug on по всем
после него sip set debug peer 2002 бессмысленно
sip set debug off
будете отбирать по конкретному пиру
paaandaaa3
Re: SIP
Сообщение paaandaaa3 »
в общем слушаю я тока один пир
как-то так
-- Executing [2000@phones:1] Dial("SIP/4000-000000f7", "SIP/2000") in new stack
Audio is at 5060
Adding codec 0x2 (gsm) to SDP
Adding codec 0x800000000000 (testlaw) to SDP
Reliably Transmitting (no NAT) to 192.168.1.37:5060:
INVITE sip:2000@192.168.1.37:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.34:5060;branch=z9hG4bK13923868
From: "IP4000" <sip:4000@192.168.1.34>;tag=as007a326c
To: <sip:2000@192.168.1.37:5060>
Contact: <sip:4000@192.168.1.34:5060>
Call-ID: 120bfd8b5caab5526ba5f73504b1e2f0@192.168.1.34:5060
CSeq: 102 INVITE
User-Agent: Asterisk PBX 1.8.7.1
Date: Wed, 23 Nov 2011 18:26:42 GMT
Content-Length: 283
v=0
o=root 1898173449 1898173449 IN IP4 192.168.1.34
s=Asterisk PBX 1.8.7.1
c=IN IP4 192.168.1.34
t=0 0
m=audio 17098 RTP/AVP 0 3 8 101
a=rtpmap:0 PCMU/8000
a=rtpmap:3 GSM/8000
a=rtpmap:8 PCMA/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
-- Called SIP/2000
<--- SIP read from UDP:192.168.1.37:5060 --->
SIP/2.0 100 Trying
CSeq: 102 INVITE
User-Agent: ATA 211 V1.0.0.46
Allow: INVITE, ACK, UPDATE, INFO, CANCEL, BYE, OPTIONS, REFER, SUBSCRIBE, NOTIFY, MESSAGE
--- (9 headers 0 lines) ---
SIP/2.0 180 Ringing
To: <sip:2000@192.168.1.37:5060>;tag=d34d98adad09a309
CSeq: 102 INVITE
Contact: <sip:2000@192.168.1.37:5060>
--- (10 headers 0 lines) ---
-- SIP/2000-000000f8 is ringing
SIP/2.0 200 OK
CSeq: 102 INVITE
Content-Length: 210
v=0
o=- 6666 137 IN IP4 192.168.1.37
s=SIP Call
c=IN IP4 192.168.1.37
t=0 0
m=audio 5004 RTP/AVP 0 101
a=sendrecv
a=ptime:20
a=fmtp:101 0-11,16
--- (11 headers 11 lines) ---
Found RTP audio format 0
Found RTP audio format 101
Capabilities: us - 0x80000008000e (gsm|ulaw|alaw|h263|testlaw), peer - audio=0x4 (ulaw)/video=0x0 (nothing)/text=0x0 (nothing), combined - 0x4 (ulaw)
Peer audio RTP is at port 192.168.1.37:5004
list_route: hop: <sip:2000@192.168.1.37:5060>
set_destination: Parsing <sip:2000@192.168.1.37:5060> for address/port to send to
set_destination: set destination to 192.168.1.37:5060
ACK sip:2000@192.168.1.37:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.34:5060;branch=z9hG4bK704fc2a6
CSeq: 102 ACK
-- SIP/2000-000000f8 answered SIP/4000-000000f7
-- Remotely bridging SIP/4000-000000f7 and SIP/2000-000000f8
Audio is at 5060
Via: SIP/2.0/UDP 192.168.1.34:5060;branch=z9hG4bK5c95a212
CSeq: 103 INVITE
X-asterisk-Info: SIP re-invite (External RTP bridge)
Content-Length: 236
v=0
o=root 1898173449 1898173450 IN IP4 192.168.1.35
c=IN IP4 192.168.1.35
t=0 0
m=audio 41000 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
SIP/2.0 100 Trying
CSeq: 103 INVITE
SIP/2.0 200 OK
CSeq: 103 INVITE
Content-Length: 210
v=0
o=- 6666 138 IN IP4 192.168.1.37
s=SIP Call
t=0 0
a=sendrecv
a=ptime:20
a=fmtp:101 0-11,16
Via: SIP/2.0/UDP 192.168.1.34:5060;branch=z9hG4bK27dfbf43
CSeq: 103 ACK
paaandaaa3
Re: SIP
А вот такая штука потом появляется
REGISTER sip:192.168.1.34:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.37:5060;branch=z9hG4bKd6c393e3
From: "2000" <sip:2000@192.168.1.34>;tag=cde09310c20e7a10
To: "2000" <sip:2000@192.168.1.34>
Call-ID: 8625cdd59adbd1bb@192.168.1.37
CSeq: 505 REGISTER
Supported: path
Expires: 900
--- (13 headers 0 lines) ---
Sending to 192.168.1.37:5060 (no NAT)
<--- Transmitting (no NAT) to 192.168.1.37:5060 --->
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 192.168.1.37:5060;branch=z9hG4bKd6c393e3;received=192.168.1.37
To: "2000" <sip:2000@192.168.1.34>;tag=as34349746
CSeq: 505 REGISTER
Server: Asterisk PBX 1.8.7.1
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="3d899b4f"
Scheduling destruction of SIP dialog '8625cdd59adbd1bb@192.168.1.37' in 32000 ms (Method: REGISTER)
Via: SIP/2.0/UDP 192.168.1.37:5060;branch=z9hG4bKba5cf06e
CSeq: 506 REGISTER
Authorization: Digest username="2000", realm="asterisk", nonce="3d899b4f", uri="sip:192.168.1.34:5060", response="3b8b6c51d477789d2cf83f9a75e42d97", algorithm=MD5
Supported: path
Expires: 900
--- (14 headers 0 lines) ---
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.37:5060;branch=z9hG4bKba5cf06e;received=192.168.1.37
CSeq: 506 REGISTER
Expires: 900
Contact: <sip:2000@192.168.1.37:5060>;expires=900
Date: Wed, 23 Nov 2011 18:37:21 GMT
paaandaaa3
Re: SIP
ddkprog писал(а):теги что ли используйте да?
то есть?) вроде нет..
Re: SIP
да, накой было выкладывать нет там UPDATE один черт
попробовать добавить в пиры
directmedia=update,nonat
nat=yes быть не должно
paaandaaa3
Re: SIP
ответ по существу..
Re: SIP
это вообще в топку
paaandaaa3
Re: SIP
Vlad1983 писал(а):да, накой было выкладывать нет там UPDATE один черт
ЕСТЬ! СПАСИБО!
