Cообщение от   Telegram-канал   asterisker_ru_bot
Asterisk Security Release Certified 18.9-cert16 ???
The Asterisk Development Team would like to announce security release Certified Asterisk 18.9-cert16. The release artifacts are available for immediate download at https://github.com/asterisk/asterisk/releases/tag/certified-18.9-cert16 and https://downloads.asterisk.org/pub/telephony/certified-asterisk Repository: https://github.com/asterisk/asterisk Tag: certified-18.9-cert16 Change Log for Release asterisk-certified-18.9-cert16 Links: Full ChangeLog GitHub Diff Tarball Downloads Summary: Commits: 1 Commit Authors: 1 Issues Resolved: 0 Security Advisories Resolved: 1 GHSA-v9q8-9j8m-5xwp: Uncontrolled ...
July 31, 2025
Подробности тут
Asterisk Security Releases 22.5.1, 21.10.1, 20.15.1, 18.26.3, Certified 20.7-cert7 ???
The Asterisk Development Team would like to announce security releases Asterisk 22.5.1, 21.10.1, 20.15.1, 18.26.3, Certified 20.7-cert7. The release artifacts are available for immediate download at https://github.com/asterisk/asterisk/releases/tag/22.5.1 https://github.com/asterisk/asterisk/releases/tag/21.10.1 https://github.com/asterisk/asterisk/releases/tag/20.15.1 https://github.com/asterisk/asterisk/releases/tag/18.26.3 https://github.com/asterisk/asterisk/releases/tag/certified-20.7-cert7   and https://downloads.asterisk.org/pub/telephony/asterisk Repository: https://github.com/asterisk/asterisk Tags: 22.5.1, 21.10.1, 20.15.1, 18.26.3, certified-20.7-cert7 Change Log  Links: Full ChangeLog GitHub Diff Tarball Downloads Summary: Commits: 2 Commit Authors: ...
July 31, 2025
Подробности тут
❗Uncontrolled Search-Path Element in safe_asterisk script may allow local privilege escalation : (GHSA-v9q8-9j8m-5xwp)
GHSA-v9q8-9j8m-5xwp
July 31, 2025
❗Remote DoS and possible RCE in asterisk/res/res_stir_shaken/verification.c : (GHSA-mrq5-74j5-f5cr)
GHSA-mrq5-74j5-f5cr
July 31, 2025
Cообщение от   Telegram-канал   Grushkovna
Мы знаем: каждый год находятся смельчаки, которые идут до площадки AsterConf по GPS и внутреннему чутью. Для всех остальных — организованный трансфер от метро. Вас встретят и посадят в машину такси за наш счет.
Ну а если любите свободу перемещений — вот подробная инструкция, как доехать самостоятельно на машине или городскbv транспортjv: https://vxlk.ru/map
Билеты на AsterConf 25 в продаже
Cообщение от   Telegram-канал   vakhtang_st
Коллеги, приветствую.
Ранее в Asterisk-е 11 версии например, при записи звукового файла через Queue -> monitor-type=Monitor, в звуковом файле, при постановке канала со стороны мембера очереди на удеражание, записывался звук установленный в music class.
В asterisk 20 + pjsip версии, звук при удержании при прочих равных в файл не попадает (просто тишина).
Может кто сталкивался?
С 11 по 20 версию очень много чего изменилось. Изменилось приложение Monitor на MixMonitor, изменился стек с chan_sip, на chan_pjsip. Т.е. изменилос все. Понятно, что оно может работать по-другому
Cообщение от   Telegram-канал   uranlink
Нормально все работает в 20 версии, пишется мелодия удержания, если поставил агент очереди
Пишем MixMonitor
Пишем MixMonitor
MixMonitor не устраивает, нужен именно monitor.
