asterisk и отправка sms своим пирам
whoim
Re: asterisk и отправка sms своим пирам
Сообщение whoim »
[2014-01-24 11:56:36] VERBOSE[5936][C-00000000] pbx.c: -- Executing [223@messages:1] NoOp("Message/ast_msg_queue", "SMS receiving dialplan invoked") in new stack
[2014-01-24 11:56:36] VERBOSE[5936][C-00000000] pbx.c: -- Executing [223@messages:2] NoOp("Message/ast_msg_queue", "To sip:223@sip.******.ru;transport=TCP") in new stack
[2014-01-24 11:56:36] VERBOSE[5936][C-00000000] pbx.c: -- Executing [223@messages:3] NoOp("Message/ast_msg_queue", "From "999" <sip:999@sip.******;transport=TCP>") in new stack
[2014-01-24 11:56:36] VERBOSE[5936][C-00000000] pbx.c: -- Executing [223@messages:4] NoOp("Message/ast_msg_queue", "Body ��лд") in new stack
[2014-01-24 11:56:36] VERBOSE[5936][C-00000000] pbx.c: -- Executing [223@messages:5] Set("Message/ast_msg_queue", "ACTUALTO=sip:223") in new stack
[2014-01-24 11:56:36] VERBOSE[5936][C-00000000] pbx.c: -- Executing [223@messages:6] MessageSend("Message/ast_msg_queue", "sip:223,"999" <sip:999@sip.******.ru;transport=TCP>") in new stack
[2014-01-24 11:56:36] VERBOSE[5936][C-00000000] pbx.c: -- Executing [223@messages:7] NoOp("Message/ast_msg_queue", "Send status is SUCCESS") in new stack
[2014-01-24 11:56:36] VERBOSE[5936][C-00000000] pbx.c: -- Executing [223@messages:8] GotoIf("Message/ast_msg_queue", "0?sendfailedmsg") in new stack
[2014-01-24 11:56:36] VERBOSE[5936][C-00000000] pbx.c: -- Executing [223@messages:9] Hangup("Message/ast_msg_queue", "") in new stack
[2014-01-24 11:56:36] VERBOSE[5936][C-00000000] pbx.c: == Spawn extension (messages, 223, 9) exited non-zero on 'Message/ast_msg_queue'
[2014-01-24 11:56:36] VERBOSE[5973] chan_sip.c: -- Got SIP MESSAGE response 400 "Malformed topmost Via header" back from host '192.168.0.186:58496'
shaverdoff
Сообщение shaverdoff »
whoim писал(а):_XXXX поправить под _XXX, так? Трехзначные номера
номерными сериями сами рулите:)))
обратите внимание как я вызываю messagesend
exten => _XXXX,n,MessageSend(${ACTUALTO},${MESSAGE(from)})
ну так и сделайте по этой статье.
у меня по alaw гуляют сообщения
отправляте так как у меня сделано.
whoim
Сообщение whoim »
я бы обратил, если бы были нужные знания. Насколько я понимаю, вызывается Message Send, которой передаются параметры, где атуалту здается выше (вырезается поле от to до конца)
ну и from
если расскажете алгоритм, я его сопоставлю со строчками и буду благодарен. Взамен могу, например, рассказать, как сделать 2.6 раздатку на уаза, отрегулировать на него пару, или запустить usb2.0 на at90usb162
whoim
Сообщение whoim »
пытаюсь
whoim
Сообщение whoim »
вопрос - строчка
exten => _XXXX,n(sendfailedmsg),Set(MESSAGE(body)="[${STRFTIME(${EPOCH},,%d%m%Y-%H:%M:%S)}] Your message to ${EXTEN} has fai
так и должна заканчиваться?
shaverdoff
нет конечно обрезалась строчка.. буфером
exten => _XXXX,n(sendfailedmsg),Set(MESSAGE(body)="[${STRFTIME(${EPOCH},,%d%m%Y-%H:%M:%S)}] Your message to ${EXTEN} has failed. Retry later.")
вот так должно быть...
а вы библию астериска не читали? там опыта на 100 человек хватит
вместо строчки диаплана в своем екстеншинконфе поставьте то что я написал.
п.с.
у меня нет уаза
У вас сообщения не отправляются или не получаются?
whoim
Сообщение whoim »
кстати
asterisk -V
Asterisk 11.2.1
shaverdoff
и? ну версия 11.2.1 и дальше что?:)
с 10 версии сообщения по-моему поддерживаются
whoim
Сообщение whoim »
да очень очень местами, времени катастрофически нехватает на то что хочется(
пытаюсь осмыслить, "что написал" - это "я делаю так"?
так и воткнул в extentions_custom, только поправил под трехзначный номерной план.
Ну и пробую так
http://stackoverflow.com/questions/1506 ... terisk-sip
Сообщения не получаются получателем. У отправителя пишется что оно получено.
shaverdoff
а пиры поддерживают получение отправку сообщений вообще?
я вот на зойпере ведре не смог принять сообщение. или я не нашел или это в платной версии только есть
только на бриа айфоновском. при включении платных сервисов получаю и и отправляю сообщения и смски
или уж если на то пошло стучитесь в аську.
