Cообщение от   Telegram-канал Independence_wxl
вот отсюда и идет этот звонок
[2024-12-21 20:44:02] VERBOSE[2394][C-00000043] netsock2.c: Using SIP RTP TOS bits 184
[2024-12-21 20:44:02] VERBOSE[2394][C-00000043] netsock2.c: Using SIP RTP CoS mark 5
[2024-12-21 20:44:02] VERBOSE[6093][C-00000043] pbx.c: Executing [197@from-trunk:1] GotoIf("SIP/trunk-goip4-1-00000062", "0?ext-local,197,1:followme-check,197,1") in new stack
[2024-12-21 20:44:02] VERBOSE[6093][C-00000043] pbx_builtins.c: Goto (followme-check,197,1)
[2024-12-21 20:44:02] VERBOSE[6093][C-00000043] pbx.c: Executing [197@followme-check:1] Gosub("SIP/trunk-goip4-1-00000062", "followme-sub,197,1()") in new stack
[2024-12-21 20:44:02] VERBOSE[6093][C-00000043] pbx.c: Executing [197@followme-sub:1] Macro("SIP/trunk-goip4-1-00000062", "user-callerid,") in new stack
[2024-12-21 20:44:02] VERBOSE[6093][C-00000043] pbx.c: Executing [s@macro-user-callerid:1] Set("SIP/trunk-goip4-1-00000062", "TOUCH_MONITOR=1734803042.110") in new stack
[2024-12-21 20:44:02] VERBOSE[6093][C-00000043] pbx.c: Executing [s@macro-user-callerid:2] Set("SIP/trunk-goip4-1-00000062", "AMPUSER=+79102450000") in new stack
[2024-12-21 20:44:02] VERBOSE[6093][C-00000043] pbx.c: Executing [s@macro-user-callerid:3] GotoIf("SIP/trunk-goip4-1-00000062", "0?report") in new stack
[2024-12-21 20:44:02] VERBOSE[6093][C-00000043] pbx.c: Executing [s@macro-user-callerid:4] ExecIf("SIP/trunk-goip4-1-00000062", "1?Set(REALCALLERIDNUM=+79102450000)") in new stack
[2024-12-21 20:44:02] VERBOSE[6093][C-00000043] pbx.c: Executing [s@macro-user-callerid:5] Set("SIP/trunk-goip4-1-00000062", "AMPUSER=") in new stack
[2024-12-21 20:44:02] VERBOSE[6093][C-00000043] pbx.c: Executing [s@macro-user-callerid:6] GotoIf("SIP/trunk-goip4-1-00000062", "0?limit") in new stack
[2024-12-21 20:44:02] VERBOSE[6093][C-00000043] pbx.c: Executing [s@macro-user-callerid:7] Set("SIP/trunk-goip4-1-00000062", "AMPUSERCIDNAME=") in new stack
[2024-12-21 20:44:02] VERBOSE[6093][C-00000043] pbx.c: Executing [s@macro-user-callerid:8] GotoIf("SIP/trunk-goip4-1-00000062", "1?report") in new stack
вот кусок лога
Cообщение от   Telegram-канал pavel_zenkevich
ни о чем не говорит)
Добрый вечер коллеги.
Подскажите пожалуйста, я уже не знаю куда копать
У меня есть номер внешний, звоню на нее и там набираю добавочный номер 112 на 112 звонок не идет и тишина, опять просить добавочный номер, набираешь 112 далее уходит звонок на 101. Через раз иногда проходит звонок
а 112 это что вообще?
112 внутренний номер
а он зареган?
да он зарегистрирован
112/112 192.168.1.52 D No No A 65038 OK (1 ms)
набираешь 112 добавочный номер, IVR начинает обратно просит набрать внутренний номер.
Если на пример набрать 125 все нормально переадресуется звонок на внутренний номер 125 так на любые другие кроме 112
© 2008 — 2024 Asterisk.ru
