[dynamic-3way]
exten => _XXX.,1,Answer()
same => n,ConfBridge(${EXTEN})
same => n,Hangup
[macro-3way-start]
exten => s,1,Set(CONFNO=6000)
same => n,ChannelRedirect(${BRIDGEPEER},dynamic-3way,${CONFNO},1)
same => n,Dial(SIP/501,30,g)
same => n,ChannelRedirect(${CHANNEL(name)},dynamic-3way,${CONFNO},1)
same => n,MacroExit()
-- Channel SIP/500-0000006a joined 'simple_bridge' basic-bridge <727d156a-85df-4508-b41e-2012cd03ab11>
-- Channel SIP/600-00000069 joined 'simple_bridge' basic-bridge <727d156a-85df-4508-b41e-2012cd03ab11>
[Feb 21 20:30:26] DTMF[4104][C-0000002b]: channel.c:3887 __ast_read: DTMF begin '*' received on SIP/600-00000069
[Feb 21 20:30:26] DTMF[4104][C-0000002b]: channel.c:3898 __ast_read: DTMF begin passthrough '*' on SIP/600-00000069
[Feb 21 20:30:26] DTMF[4104][C-0000002b]: channel.c:3801 __ast_read: DTMF end '*' received on SIP/600-00000069, duration 100 ms
[Feb 21 20:30:26] DTMF[4104][C-0000002b]: channel.c:3842 __ast_read: DTMF end accepted with begin '*' on SIP/600-00000069
[Feb 21 20:30:26] DTMF[4104][C-0000002b]: channel.c:3857 __ast_read: DTMF end '*' detected to have actual duration 79 on the wire, emulation will be triggered on SIP/600-00000069
[Feb 21 20:30:26] DTMF[4104][C-0000002b]: channel.c:3864 __ast_read: DTMF end '*' has duration 79 but want minimum 80, emulating on SIP/600-00000069
[Feb 21 20:30:26] DTMF[4104][C-0000002b]: channel.c:3921 __ast_read: DTMF end emulation of '*' queued on SIP/600-00000069
[Feb 21 20:30:26] DTMF[4104][C-0000002b]: channel.c:3887 __ast_read: DTMF begin '0' received on SIP/600-00000069
[Feb 21 20:30:26] DTMF[4104][C-0000002b]: channel.c:3898 __ast_read: DTMF begin passthrough '0' on SIP/600-00000069
[Feb 21 20:30:26] DTMF[4104][C-0000002b]: channel.c:3801 __ast_read: DTMF end '0' received on SIP/600-00000069, duration 100 ms
[Feb 21 20:30:26] DTMF[4104][C-0000002b]: channel.c:3842 __ast_read: DTMF end accepted with begin '0' on SIP/600-00000069
[Feb 21 20:30:26] DTMF[4104][C-0000002b]: channel.c:3857 __ast_read: DTMF end '0' detected to have actual duration 79 on the wire, emulation will be triggered on SIP/600-00000069
[Feb 21 20:30:26] DTMF[4104][C-0000002b]: channel.c:3864 __ast_read: DTMF end '0' has duration 79 but want minimum 80, emulating on SIP/600-00000069
[Feb 21 20:30:27] DTMF[4104][C-0000002b]: channel.c:3921 __ast_read: DTMF end emulation of '0' queued on SIP/600-00000069
-- Executing [s@macro-3way-start:1] Set("SIP/600-00000069", "CONFNO=6000") in new stack
-- Executing [s@macro-3way-start:2] ChannelRedirect("SIP/600-00000069", "SIP/500-0000006a,dynamic-3way,6000,1") in new stack
-- Executing [s@macro-3way-start:3] Dial("SIP/600-00000069", "SIP/501,30,g") in new stack
-- Channel SIP/500-0000006a left 'simple_bridge' basic-bridge <727d156a-85df-4508-b41e-2012cd03ab11>
== Using SIP RTP TOS bits 184
-- Executing [6000@dynamic-3way:1] Answer("SIP/500-0000006a", "") in new stack
-- Executing [6000@dynamic-3way:2] ConfBridge("SIP/500-0000006a", "6000") in new stack
-- Called SIP/501
-- Channel CBAnn/6000-00000030;2 joined 'softmix' base-bridge <156a44fc-fcaa-459b-af31-844fbbf47cdd>
-- <SIP/500-0000006a> Playing 'conf-onlyperson.ulaw' (language 'ru')
-- SIP/501-0000006b is ringing
-- SIP/501-0000006b answered SIP/600-00000069
-- Channel SIP/501-0000006b joined 'simple_bridge' basic-bridge <6249ff41-66ce-42a9-b729-67fef9af1c86>
-- Executing [s@macro-3way-start:4] ChannelRedirect("SIP/600-00000069", "SIP/600-00000069,dynamic-3way,6000,1") in new stack
== Channel 'SIP/600-00000069' jumping out of macro '3way-start'
-- Channel SIP/600-00000069 left 'simple_bridge' basic-bridge <727d156a-85df-4508-b41e-2012cd03ab11>
-- Executing [6000@dynamic-3way:1] Answer("SIP/600-00000069", "") in new stack
== Spawn extension (dynamic-3way, 6000, 1) exited non-zero on 'SIP/600-00000069'
-- <SIP/500-0000006a> Playing 'confbridge-join.ulaw' (language 'ru')
-- <CBAnn/6000-00000030;1> Playing 'confbridge-join.slin16' (language 'en')
-- Channel SIP/500-0000006a joined 'softmix' base-bridge <156a44fc-fcaa-459b-af31-844fbbf47cdd>
*CLI> confbridge list
Conference Bridge Name Users Marked Locked Muted
6000 1 0 No No
*CLI> core show channels
Channel Location State Application(Data)
SIP/500-0000006a 6000@dynamic-3way:2 Up ConfBridge(6000)
SIP/501-0000006b (None) Up AppDial((Outgoing Line))
CBAnn/6000-00000030; s@default:1 Up (None)
буду благодарен за любую помощь, хотя бы знать куда копать.
