root@ats3:/var/log/asterisk# asterisk -rx "dahdi show status"
Description                              Alarms  IRQ    bpviol CRC    Fra Codi Options  LBO
Parabel Quasar 0 Span 1                  OK      0      0      0      CCS HDB3          0 db (CSU)/0-133 feet (DSX-1)
Parabel Quasar 0 Span 2                  OK      0      0      0      CCS HDB3          0 db (CSU)/0-133 feet (DSX-1)   LG
Parabel Quasar 0 Span 3                  BLU/RED 0      0      0      CCS HDB3          0 db (CSU)/0-133 feet (DSX-1)
Parabel Quasar 0 Span 4                  BLU/RED 0      0      0      CCS HDB3          0 db (CSU)/0-133 feet (DSX-1)
Parabel Quasar 0 Span 5                  OK      0      0      0      CCS HDB3          0 db (CSU)/0-133 feet (DSX-1)
Parabel Quasar 0 Span 6                  OK      0      0      0      CCS HDB3          0 db (CSU)/0-133 feet (DSX-1)   КОМСТАР
Parabel Quasar 0 Span 7                  OK      0      0      0      CCS HDB3          0 db (CSU)/0-133 feet (DSX-1)
Parabel Quasar 0 Span 8                  OK      0      0      0      CCS HDB3          0 db (CSU)/0-133 feet (DSX-1)
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 < TEI: 0 State 7(Multi-frame established)
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 < V(A)=75, V(S)=75, V(R)=3
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 < K=7, RC=0, l3_initiated=1, reject_except=0, ack_pend=0
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 < T200_id=0, N200=3, T203_id=32768
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 < [ 02 01 06 96 08 02 22 25 45 08 02 80 90 1e 02 82 88 ]
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 < Informational frame:
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 < SAPI: 00 C/R: 1 EA: 0
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 < TEI: 000 EA: 1
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 < N(S): 003 0: 0
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 < N(R): 075 P: 0
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 < 13 bytes of data
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 < Protocol Discriminator: Q.931 (8) len=13
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 < TEI=0 Call Ref: len= 2 (reference 8741/0x2225) (Sent from originator)
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 < Message Type: DISCONNECT (69)
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 < [08 02 80 90]
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 < Cause (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) Spare: 0 Location: User (0)
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 < Ext: 1 Cause: Normal Clearing (16), class = Normal Event (1) ]
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 < [1e 02 82 88]
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 < Progress Indicator (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) 0: 0 Location: Public network serving the
local user (2)
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 < Ext: 1 Progress Description: Inband information or appropriate pattern now availabl
e. (8) ]
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 -- Got ACK for N(S)=75 to (but not including) N(S)=75
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 -- T200 requested to stop when not started
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 T203 requested to start without stopping first
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 -- Starting T203 timer
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 Received message for call 0xb5ed5958 on link 0xb6247934 TEI/SAPI 0/0
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 -- Processing IE 8 (cs0, Cause)
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 -- Processing IE 30 (cs0, Progress Indicator)
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 -- Found active call: 0xb5ed5958 cref:8741
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 q931.c:8707 post_handle_q931_message: Call 8741 enters state 12 (Disconnect Indication). Hold state: Idle
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 > TEI: 0 State 7(Multi-frame established)
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 > V(A)=75, V(S)=75, V(R)=4
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 > K=7, RC=0, l3_initiated=1, reject_except=0, ack_pend=0
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 > T200_id=0, N200=3, T203_id=32768
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 > [ 02 01 01 08 ]
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 > Supervisory frame:
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 > SAPI: 00 C/R: 1 EA: 0
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 > TEI: 000 EA: 1
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 > Zero: 0 S: 0 01: 1 [ RR (receive ready) ]
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 > N(R): 004 P/F: 0
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 > 0 bytes of data
[2012-04-10 15:22:47] VERBOSE[1520] chan_dahdi.c: PRI Span: 6 Done handling message for SAPI/TEI=0/0
[2012-04-10 15:22:47] VERBOSE[1520] sig_pri.c: Span 6: Processing event PRI_EVENT_HANGUP_REQ
[2012-04-10 15:22:47] VERBOSE[1520] sig_pri.c: -- Span 6: Channel 0/29 got hangup request, cause 16
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 q931.c:6837 q931_hangup: Hangup other cref:36178
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 q931.c:6594 __q931_hangup: ourstate Active, peerstate Active, hold-state Idle
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 q931.c:5783 q931_disconnect: Call 36178 enters state 11 (Disconnect Request). Hold state: Idle
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 > DL-DATA request
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 > Protocol Discriminator: Q.931 (8) len=9
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 > TEI=0 Call Ref: len= 2 (reference 3410/0xD52) (Sent from originator)
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 > Message Type: DISCONNECT (69)
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 TEI=0 Transmitting N(S)=20, window is open V(A)=20 K=7
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 > TEI: 0 State 7(Multi-frame established)
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 > V(A)=20, V(S)=20, V(R)=3
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 > K=7, RC=0, l3_initiated=0, reject_except=0, ack_pend=0
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 > T200_id=0, N200=3, T203_id=16384
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 > [ 02 01 28 06 08 02 0d 52 45 08 02 81 90 ]
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 > Informational frame:
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 > SAPI: 00 C/R: 1 EA: 0
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 > TEI: 000 EA: 1
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 > N(S): 020 0: 0
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 > N(R): 003 P: 0
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 > 9 bytes of data
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 > [08 02 81 90]
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 > Cause (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) Spare: 0 Location: Private network serving the local user (1)
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 > Ext: 1 Cause: Normal Clearing (16), class = Normal Event (1) ]
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 -- Stopping T203 timer
[2012-04-10 15:22:47] VERBOSE[24915] chan_dahdi.c: PRI Span: 2 -- Starting T200 timer
local user (2)
e. (8) ]
