Frepbx Проблемы с обновление OS
iliaxxx
Сообщение iliaxxx »
Стоит FreePBX 14.0.13.12. Она на основе Sangoma.
Недавно столкнулся с проблемой при обновлении. При вводе команды yum update, имею выхлоп:
[root@sip ~]# yum update
Загружены модули: fastestmirror, versionlock
Loading mirror speeds from cached hostfile
Could not retrieve mirrorlist http://mirrorlist.sangoma.net/?release=$releasever&arch=x86_64&repo=os&dist=$dist&staging=$staging error was
14: HTTP Error 500 - Internal Server Error
 One of the configured repositories failed (Неизвестно),
 and yum doesn't have enough cached data to continue. At this point the only
 safe thing yum can do is fail. There are a few ways to work "fix" this:
     1. Contact the upstream for the repository and get them to fix the problem.
     2. Reconfigure the baseurl/etc. for the repository, to point to a working
        upstream. This is most often useful if you are using a newer
        distribution release than is supported by the repository (and the
        packages for the previous distribution release still work).
     3. Run the command with the repository temporarily disabled
            yum --disablerepo=<repoid> ...
     4. Disable the repository permanently, so yum won't use it by default. Yum
        will then just ignore the repository until you permanently enable it
        again or use --enablerepo for temporary usage:
            yum-config-manager --disable <repoid>
        or
            subscription-manager repos --disable=<repoid>
     5. Configure the failing repository to be skipped, if it is unavailable.
        Note that yum will try to contact the repo. when it runs most commands,
        so will have to try and fail each time (and thus. yum will be be much
        slower). If it is a very temporary problem though, this is often a nice
        compromise:
            yum-config-manager --save --setopt=<repoid>.skip_if_unavailable=true
Cannot find a valid baseurl for repo: sng-base/$releasever/x86_64
Что ж, трабла знакомая, проблема в DNS как всегда, но проверив настройки DNS, понял что не в нем дело, для проверки пиганул mirrorlist.sangoma.net
[root@sip ~]# ping mirrorlist.sangoma.net
PING mirrorlist.sangoma.net (199.102.239.91) 56(84) bytes of data.
64 bytes from 199.102.239.91 (199.102.239.91): icmp_seq=1 ttl=52 time=151 ms
64 bytes from 199.102.239.91 (199.102.239.91): icmp_seq=2 ttl=52 time=151 ms
^C
--- mirrorlist.sangoma.net ping statistics ---
3 packets transmitted, 2 received, 33% packet loss, time 2000ms
rtt min/avg/max/mdev = 151.204/151.227/151.251/0.389 ms
Как видно, все пакеты идут....
Пробовал очистить кэш, тоже не помогает. Пробовал отключать репозиторий на который ругается, оказывается по цепочки, ругается он почти на все репозитории.
Пробовал репозитории копировать с рабочего сервера то же версии, не помогло.
Есть у кого мысли?
Re: Frepbx Проблемы с обновление OS
есть.
фриланц завется
iliaxxx писал(а):Как видно, все пакеты идут....
Это ожидаемо, т.к.исходя из ошибки 500 говорит о том, что ответ вы получили, а значит dns тут скорее всего не виноват, токль если он резолвит не в туда.вот это надо было проверить, что выдаёт ваш dns, а что гугловский.
Вы пробовали зайти по урлу или просто по домену сами? Попробуйте, получите ту же 500ю.
Соответственно надо или гуглить, наверняка проблему могли заметить не только вы, или писать владельцам репы.
