поставил freeswitch.msi под windows7 на локальном компьютере
вбиваю в x-lite ip адрес 127.0.0.1 - система не подключается
как узнать какой ip адрес у инсталлированного freeswitch в windows?
<profiles>
<X-PRE-PROCESS cmd="include" data="../sip_profiles/*.xml"/>
</profiles>
...Код: Выделить всё
<?xml version="1.0"?>
<include>
<profile name="sipinterface_1">
<settings>
<param name="enable-timer" value="false"/>
<param name="user-agent-string" value="Configured by 2600hz!"/>
<param name="rtp-timer-name" value="soft"/>
<param name="codec-prefs" value="$${global_codec_prefs}"/>
<param name="inbound-codec-negotiation" value="generous"/>
<param name="inbound-reg-force-matching-username" value="true"/>
<param name="nonce-ttl" value="86400"/>
<param name="rfc2833-pt" value="101"/>
<param name="manage-presence" value="true"/>
<param name="auth-calls" value="true"/>
<param name="sip-ip" value="10.56.58.7"/>
<param name="rtp-ip" value="10.56.58.7"/>
<param name="sip-port" value="5060"/>
<param name="nat-options-ping" value="true"/>
<param name="all-reg-options-ping" value="true"/>
<param name="ext-sip-ip" value="auto-nat"/>
<param name="ext-rtp-ip" value="auto-nat"/>
<param name="context" value="context_1"/>
<param name="force-register-domain" value="$${location_1}"/>
<param name="force-register-db-domain" value="$${location_1}"/>
<param name="apply-nat-acl" value="nat.auto"/>
<param name="apply-inbound-acl" value="net_list_5"/>
<param name="contact-params" value="tport=udp"/>
<param name="register-transport" value="udp"/>
<param name="bind-params" value="transport=udp"/>
<param name="odbc-dsn" value="$${odbc_1}"/>
</settings>
</profile>
<profile name="sipinterface_3">
<settings>
<param name="auth-calls" value="false"/>
<param name="sip-port" value="5080"/>
<param name="context" value="context_2"/>
</settings>
<gateways>
<gateway name="trunk_1">
<param name="realm" value="10.56.58.5"/>
<param name="username" value="TCAPI_User"/>
<param name="password" value="TCAPI_User"/>
<param name="register" value="false"/>
<param name="caller-id-in-from" value="true"/>
</gateway>
<gateway name="trunk_2">
<param name="realm" value="10.56.57.233"/>
</gateway>
<gateway name="trunk_3">
<param name="realm" value="10.56.1.7"/>
</gateway>
</gateways>
<domains>
<domain name="all" alias="true" parse="false"/>
</domains>
<aliases>
<alias name="$${location_1}"/>
</aliases>
</profile>
</include>
