ошибки при обработке call файла
robert
Сообщение robert »
астериском вызывается call файл
Channel: SIP/sipnet.ru/89001231234
MaxRetries:1
RetryTime:60
WaitTime:30
Context: outcall
Extension:1000
Priority:1
и получаются ошибки
[Nov 13 06:17:45] VERBOSE[7381] asterisk.c:     -- Remote UNIX connection disconnected
[Nov 13 06:17:49] WARNING[4563] pbx_spool.c: Unable to set utime on /var/spool/asterisk/outgoing/go.call: Operation not permitted
[Nov 13 06:17:49] VERBOSE[7382] pbx_spool.c:     -- Attempting call on SIP/sipnet.ru/89001231234 for 1000@outcall:1 (Retry 1)
[Nov 13 06:17:49] VERBOSE[7382] netsock2.c:   == Using SIP RTP TOS bits 184
[Nov 13 06:17:49] VERBOSE[7382] netsock2.c:   == Using SIP RTP CoS mark 5
[Nov 13 06:17:49] NOTICE[4536] chan_sip.c: Failed to authenticate on INVITE to '"Unknown" <sip:Unknown@192.168.32.166>;tag=as684412aa'
[Nov 13 06:17:49] NOTICE[7382] pbx_spool.c: Call failed to go through, reason (8) Congestion (circuits busy)
[Nov 13 06:17:49] WARNING[7382] pbx_spool.c: Unable to set utime on /var/spool/asterisk/outgoing/go.call: Operation not permitted
что нужно донастроить?
gosha
Re: ошибки при обработке call файла
Сообщение gosha »
пермишенсы на call файл поправить и sip debug on сделать...
robert
Сообщение robert »
сделал вот лог
[Nov 13 07:43:10] VERBOSE[4540] chan_sip.c:
<--- SIP read from UDP:192.168.32.1:5060 --->
[Nov 13 07:43:11] VERBOSE[4540] chan_sip.c:
<--- SIP read from UDP:192.168.32.1:15200 --->
[Nov 13 07:43:16] VERBOSE[4540] chan_sip.c: Reliably Transmitting (NAT) to 192.168.32.1:5060:
OPTIONS sip:1000@56.213.171.212:5060;rinstance=2d145c6148823511;transport=UDP SIP/2.0
Via: SIP/2.0/UDP 192.168.32.166:5060;branch=z9hG4bK4b1a991c;rport
From: "Unknown" <sip:Unknown@192.168.32.166>;tag=as7e6c08bf
To: <sip:1000@56.213.171.212:5060;rinstance=2d145c6148823511;transport=UDP>
Contact: <sip:Unknown@192.168.32.166:5060>
Call-ID: 534e3e055deaaca50e6c22b1391cad82@192.168.32.166:5060
CSeq: 102 OPTIONS
User-Agent: FPBX-2.8.1(1.8.11.0)
Date: Tue, 13 Nov 2012 03:43:16 GMT
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.32.166:5060;branch=z9hG4bK4b1a991c;rport=5060
Contact: <sip:192.168.32.1:5060>
To: <sip:1000@56.213.171.212:5060;rinstance=2d145c6148823511;transport=UDP>;tag=d750755f
From: "Unknown"<sip:Unknown@192.168.32.166>;tag=as7e6c08bf
CSeq: 102 OPTIONS
Accept: application/sdp, application/sdp
Accept-Language: en
Allow: INVITE, ACK, CANCEL, BYE, NOTIFY, REFER, MESSAGE, OPTIONS, INFO, SUBSCRIBE
Supported: replaces, norefersub, extended-refer, X-cisco-serviceuri
User-Agent: Zoiper rev.11137
Allow-Events: presence, kpml
[Nov 13 07:43:16] VERBOSE[4540] chan_sip.c: --- (14 headers 0 lines) ---
[Nov 13 07:43:16] VERBOSE[4540] chan_sip.c: Really destroying SIP dialog '534e3e055deaaca50e6c22b1391cad82@192.168.32.166:5060' Method: OPTIONS
[Nov 13 07:43:17] VERBOSE[4540] chan_sip.c: Reliably Transmitting (NAT) to 212.53.40.40:5060:
OPTIONS sip:sipnet.ru SIP/2.0
Via: SIP/2.0/UDP 192.168.32.166:5060;branch=z9hG4bK2f7597d5;rport
From: "Unknown" <sip:id_sip@192.168.32.166>;tag=as7a06608a
To: <sip:sipnet.ru>
Contact: <sip:id_sip@192.168.32.166:5060>
Call-ID: 22a3c6da0c4b14a51cf86e997c292674@192.168.32.166:5060
CSeq: 102 OPTIONS
Date: Tue, 13 Nov 2012 03:43:17 GMT
[Nov 13 07:43:17] VERBOSE[4540] chan_sip.c: Reliably Transmitting (NAT) to 192.168.32.1:15200:
OPTIONS sip:1001@192.168.32.1:15200;rinstance=837f89f6925ce507 SIP/2.0
Via: SIP/2.0/UDP 192.168.32.166:5060;branch=z9hG4bK0440b3a5;rport
From: "Unknown" <sip:Unknown@192.168.32.166>;tag=as0afa6cba
To: <sip:1001@192.168.32.1:15200;rinstance=837f89f6925ce507>
Call-ID: 2d91546740305068633506ee7385f55e@192.168.32.166:5060
CSeq: 102 OPTIONS
<--- SIP read from UDP:212.53.40.40:5060 --->
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.32.166:5060;branch=z9hG4bK2f7597d5;rport=51586;received=56.213.171.212
To: <sip:sipnet.ru>;tag=AAD1C86F
CSeq: 102 OPTIONS
Date: Tue, 13 Nov 2012 13:14:00 GMT
Allow: PUBLISH,SUBSCRIBE
Supported: path,gruu
Allow-Events: presence,message-summary,reg,dialog,line-seize,keep-alive,refer
Server: CommuniGatePro/6.0c2
[Nov 13 07:43:17] VERBOSE[4540] chan_sip.c: --- (12 headers 0 lines) ---
[Nov 13 07:43:17] VERBOSE[4540] chan_sip.c: Really destroying SIP dialog '22a3c6da0c4b14a51cf86e997c292674@192.168.32.166:5060' Method: OPTIONS
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.32.166:5060;branch=z9hG4bK0440b3a5;rport=5060
Contact: <sip:192.168.32.1:15200>
To: <sip:1001@192.168.32.1:15200;rinstance=837f89f6925ce507>;tag=0c640a06
From: "Unknown"<sip:Unknown@192.168.32.166>;tag=as0afa6cba
CSeq: 102 OPTIONS
Accept-Language: en
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, NOTIFY, MESSAGE, SUBSCRIBE, INFO
User-Agent: eyeBeam release 1003s stamp 31159
[Nov 13 07:43:17] VERBOSE[4540] chan_sip.c: Really destroying SIP dialog '2d91546740305068633506ee7385f55e@192.168.32.166:5060' Method: OPTIONS
robert
Сообщение robert »
Trunk Name: sipnet
Outbound Caller ID: id_sip
настройки sip транка - Outgoing Settings
host=sipnet.ru
username=id_sip
secret=пароль
insecure=very&invite
fromuser=id_sipnet
fromdomain=sipnet.ru
dtmfmode=rfc2833
trustrpid=no
sendrpid=no
canreinvite=no
context=outgoing
Extension:1000
имеет пароль ?!
robert
Сообщение robert »
да пароль 1000
оставте поле пустым
и попробуйте еще раз
robert
Сообщение robert »
сделал все так же Failed to authenticate on INVITE to '"Unknown"
Channel: SIP/имя-пира/89001231234
robert
Сообщение robert »
заработало
теперь делаю
Channel: SIP/sipnet/номермобильного1
Callerid: 1000
MaxRetries: 5
RetryTime: 300
WaitTime: 45
Extension: SIP/sipnet/номермобильного2
Priority: 1
мобильный 1 набирается и в трубку сервер проговаривает SIP/sipnet/номермобильного2 и говорит что не может до него дозвониться,
как правильно вызвать номермобильного2
© 2008 — 2024 Asterisk.ru
