обрыв входящих на 31 секунде и не не работает прямой набор
reabool
Сообщение reabool »
Freepbx настриивал через web интерфейс. Стоит за NATо чем указано в настройках Asterisk для sip
Порт 5060 проброшен на роутере в соответствии с рекомендацией провайдера телефонного (зебрателеком)
Звонил к ним говорят Обрыв у вас. Ваша АТС сообщает Bye и вешает трубку.
В логах :
[2023-01-23 20:27:39] VERBOSE[11213][C-00000009] bridge_channel.c: Channel SIP/in7XXXXXXXX5-0000000f joined 'simple_bridge' basic-bridge <8faf08c9-318a-4558-a4eb-1309ea985d16>
890 [2023-01-23 20:27:51] NOTICE[2426] chan_sip.c: Disconnecting call 'SIP/in7XXXXXXXX5-0000000f' for lack of RTP activity in 31 seconds
891 [2023-01-23 20:27:51] VERBOSE[11213][C-00000009] bridge_channel.c: Channel SIP/in7XXXXXXXX5-0000000f left 'simple_bridge' basic-bridge <8faf08c9-318a-4558-a4eb-1309ea985d16>
Если посмотреть входящий звонок в консоли, через команду asterisk -rvvvvv
== Using SIP RTP TOS bits 184
> 0x7f470c1f84a0 -- Strict RTP learning after remote address set to: 213.XXX.XXX.XXX:21954
-- Executing [XXXXXXXX@from-trunk-sip-outXXXXXXXX:1] Set("SIP/inXXXXXXXX-00000013", "GROUP()=OUT_1") in new stack
-- Executing [XXXXXXXX@from-trunk-sip-outXXXXXXXX:2] Goto("SIP/inXXXXXXXX-00000013", "from-trunk,XXXXXXXX,1") in new stack
-- Goto (from-trunk,XXXXXXXX,1)
-- Executing [XXXXXXXX@from-trunk:1] Set("SIP/inXXXXXXXX-00000013", "__DIRECTION=INBOUND") in new stack
-- Executing [XXXXXXXX@from-trunk:2] Gosub("SIP/inXXXXXXXX-00000013", "sub-record-check,s,1(in,XXXXXXXX,dontcare)") in new stack
-- Executing [s@sub-record-check:1] GotoIf("SIP/inXXXXXXXX-00000013", "0?initialized") in new stack
-- Executing [s@sub-record-check:2] Set("SIP/inXXXXXXXX-00000013", "__REC_STATUS=INITIALIZED") in new stack
-- Executing [s@sub-record-check:3] Set("SIP/inXXXXXXXX-00000013", "NOW=1674499709") in new stack
-- Executing [s@sub-record-check:4] Set("SIP/inXXXXXXXX-00000013", "__DAY=23") in new stack
-- Executing [s@sub-record-check:5] Set("SIP/inXXXXXXXX-00000013", "__MONTH=01") in new stack
-- Executing [s@sub-record-check:6] Set("SIP/inXXXXXXXX-00000013", "__YEAR=2023") in new stack
-- Executing [s@sub-record-check:7] Set("SIP/inXXXXXXXX-00000013", "__TIMESTR=20230123-214829") in new stack
-- Executing [s@sub-record-check:8] Set("SIP/inXXXXXXXX-00000013", "__FROMEXTEN=unknown") in new stack
-- Executing [s@sub-record-check:9] Set("SIP/inXXXXXXXX-00000013", "__MON_FMT=wav") in new stack
-- Executing [s@sub-record-check:10] NoOp("SIP/inXXXXXXXX-00000013", "Recordings initialized") in new stack
-- Executing [s@sub-record-check:11] ExecIf("SIP/inXXXXXXXX-00000013", "0?Set(ARG3=dontcare)") in new stack
-- Executing [s@sub-record-check:12] Set("SIP/inXXXXXXXX-00000013", "REC_POLICY_MODE_SAVE=") in new stack
-- Executing [s@sub-record-check:13] ExecIf("SIP/inXXXXXXXX-00000013", "0?Set(REC_STATUS=NO)") in new stack
-- Executing [s@sub-record-check:14] GotoIf("SIP/inXXXXXXXX-00000013", "2?checkaction") in new stack
-- Executing [s@sub-record-check:17] GotoIf("SIP/inXXXXXXXX-00000013", "1?sub-record-check,in,1") in new stack
-- Goto (sub-record-check,in,1)
-- Executing [in@sub-record-check:1] NoOp("SIP/inXXXXXXXX-00000013", "Inbound Recording Check to XXXXXXXX") in new stack
-- Executing [in@sub-record-check:2] Set("SIP/inXXXXXXXX-00000013", "FROMEXTEN=unknown") in new stack
-- Executing [in@sub-record-check:3] ExecIf("SIP/inXXXXXXXX-00000013", "10?Set(FROMEXTEN=XXXXXXXX2)") in new stack
-- Executing [in@sub-record-check:4] Gosub("SIP/inXXXXXXXX-00000013", "recordcheck,1(dontcare,in,XXXXXXXX)") in new stack
-- Executing [recordcheck@sub-record-check:1] NoOp("SIP/inXXXXXXXX-00000013", "Starting recording check against dontcare") in new stack
-- Executing [recordcheck@sub-record-check:2] Goto("SIP/inXXXXXXXX-00000013", "dontcare") in new stack
-- Goto (sub-record-check,recordcheck,3)
-- Executing [recordcheck@sub-record-check:3] Return("SIP/inXXXXXXXX-00000013", "") in new stack
-- Executing [in@sub-record-check:5] Return("SIP/inXXXXXXXX-00000013", "") in new stack
-- Executing [XXXXXXXX@from-trunk:3] Set("SIP/inXXXXXXXX-00000013", "CHANNEL(tonezone)=ru") in new stack
-- Executing [XXXXXXXX@from-trunk:4] Set("SIP/inXXXXXXXX-00000013", "__FROM_DID=XXXXXXXX") in new stack
-- Executing [XXXXXXXX@from-trunk:5] Set("SIP/inXXXXXXXX-00000013", "returnhere=1") in new stack
-- Executing [XXXXXXXX@from-trunk:6] Gosub("SIP/inXXXXXXXX-00000013", "app-blacklist-check,s,1()") in new stack
-- Executing [s@app-blacklist-check:1] GotoIf("SIP/inXXXXXXXX-00000013", "0?blacklisted") in new stack
-- Executing [s@app-blacklist-check:2] Set("SIP/inXXXXXXXX-00000013", "CALLED_BLACKLIST=1") in new stack
-- Executing [s@app-blacklist-check:3] Return("SIP/inXXXXXXXX-00000013", "") in new stack
-- Executing [XXXXXXXX@from-trunk:7] Set("SIP/inXXXXXXXX-00000013", "CDR(did)=XXXXXXXX") in new stack
-- Executing [XXXXXXXX@from-trunk:8] GotoIf("SIP/inXXXXXXXX-00000013", "0?") in new stack
-- Executing [XXXXXXXX@from-trunk:9] ExecIf("SIP/inXXXXXXXX-00000013", "1 ?Set(CALLERID(name)=XXXXXXXX2)") in new stack
-- Executing [XXXXXXXX@from-trunk:10] Set("SIP/inXXXXXXXX-00000013", "__MOHCLASS=") in new stack
-- Executing [XXXXXXXX@from-trunk:11] Set("SIP/inXXXXXXXX-00000013", "__REVERSAL_REJECT=FALSE") in new stack
-- Executing [XXXXXXXX@from-trunk:12] GotoIf("SIP/inXXXXXXXX-00000013", "1?post-reverse-charge") in new stack
-- Goto (from-trunk,XXXXXXXX,14)
-- Executing [XXXXXXXX@from-trunk:14] NoOp("SIP/inXXXXXXXX-00000013", "") in new stack
-- Executing [XXXXXXXX@from-trunk:15] Set("SIP/inXXXXXXXX-00000013", "__CALLINGNAMEPRES_SV=allowed_not_screened") in new stack
-- Executing [XXXXXXXX@from-trunk:16] Set("SIP/inXXXXXXXX-00000013", "__CALLINGNUMPRES_SV=allowed_not_screened") in new stack
-- Executing [XXXXXXXX@from-trunk:17] Set("SIP/inXXXXXXXX-00000013", "CALLERID(name-pres)=allowed_not_screened") in new stack
-- Executing [XXXXXXXX@from-trunk:18] Set("SIP/inXXXXXXXX-00000013", "CALLERID(num-pres)=allowed_not_screened") in new stack
-- Executing [XXXXXXXX@from-trunk:19] NoOp("SIP/inXXXXXXXX-00000013", "CallerID Entry Point") in new stack
-- Executing [XXXXXXXX@from-trunk:20] Set("SIP/inXXXXXXXX-00000013", "__CRM_DIRECTION=INBOUND") in new stack
-- Executing [XXXXXXXX@from-trunk:21] Set("SIP/inXXXXXXXX-00000013", "__CRM_SOURCE=XXXXXXXX2") in new stack
-- Executing [XXXXXXXX@from-trunk:22] Set("SIP/inXXXXXXXX-00000013", "__CRM_LINKEDID=1674499709.23") in new stack
-- Executing [XXXXXXXX@from-trunk:23] AGI("SIP/inXXXXXXXX-00000013", "agi://127.0.0.1/sangomacrm.agi,true") in new stack
-- <SIP/inXXXXXXXX-00000013>AGI Script agi://127.0.0.1/sangomacrm.agi completed, returning 0
-- Executing [XXXXXXXX@from-trunk:24] ExecIf("SIP/inXXXXXXXX-00000013", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack
-- Executing [XXXXXXXX@from-trunk:25] Goto("SIP/inXXXXXXXX-00000013", "ivr-2,s,1") in new stack
-- Goto (ivr-2,s,1)
-- Executing [s@ivr-2:1] Set("SIP/inXXXXXXXX-00000013", "_IVR_CONTEXT_ivr-2=") in new stack
-- Executing [s@ivr-2:2] Set("SIP/inXXXXXXXX-00000013", "_IVR_CONTEXT=ivr-2") in new stack
-- Executing [s@ivr-2:3] Set("SIP/inXXXXXXXX-00000013", "__IVR_RETVM=") in new stack
-- Executing [s@ivr-2:4] GotoIf("SIP/inXXXXXXXX-00000013", "0?skip") in new stack
-- Executing [s@ivr-2:5] Answer("SIP/inXXXXXXXX-00000013", "") in new stack
-- Executing [s@ivr-2:6] Set("SIP/inXXXXXXXX-00000013", "IVR_MSG=custom/hellohello") in new stack
-- Executing [s@ivr-2:7] Set("SIP/inXXXXXXXX-00000013", "TIMEOUT(digit)=3") in new stack
-- Digit timeout set to 3.000
-- Executing [s@ivr-2:8] ExecIf("SIP/inXXXXXXXX-00000013", "1?Background(custom/hellohello)") in new stack
-- <SIP/inXXXXXXXX-00000013> Playing 'custom/hellohello.slin' (language 'ru')
-- Executing [s@ivr-2:9] WaitExten("SIP/inXXXXXXXX-00000013", "5,") in new stack
-- Timeout on SIP/inXXXXXXXX-00000013, going to 't'
-- Executing [t@ivr-2:1] Playback("SIP/inXXXXXXXX-00000013", "no-valid-responce-transfering") in new stack
-- <SIP/inXXXXXXXX-00000013> Playing 'no-valid-responce-transfering.ulaw' (language 'ru')
А цель у входящих после транка попасть в AVR из нее или по голосу на прямой добор три цифры или в очереь там 3 внутренних номера. .
Относительно DTMF он там какую то кашу получает вместо цифр гдето тут:
60 [2023-01-22 22:15:11] VERBOSE[15749][C-0000000d] pbx.c: Executing [7XXXXXXXX5@from-trunk:24] ExecIf("SIP/in7XXXXXXXX5-0000000f", "1?Set(CHANNEL(hangup_handler_push)=crm-hangup,s,1)") in new stack
61 [2023-01-22 22:15:11] VERBOSE[15749][C-0000000d] pbx.c: Executing [7XXXXXXXX5@from-trunk:25] Goto("SIP/in7XXXXXXXX5-0000000f", "ivr-1,s,1") in new stack
62 [2023-01-22 22:15:11] VERBOSE[15749][C-0000000d] pbx_builtins.c: Goto (ivr-1,s,1)
63 [2023-01-22 22:15:11] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@ivr-1:1] Set("SIP/in7XXXXXXXX5-0000000f", "INVALID_LOOPCOUNT=0") in new stack
64 [2023-01-22 22:15:11] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@ivr-1:2] Set("SIP/in7XXXXXXXX5-0000000f", "_IVR_CONTEXT_ivr-1=") in new stack
65 [2023-01-22 22:15:11] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@ivr-1:3] Set("SIP/in7XXXXXXXX5-0000000f", "_IVR_CONTEXT=ivr-1") in new stack
66 [2023-01-22 22:15:11] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@ivr-1:4] Set("SIP/in7XXXXXXXX5-0000000f", "__IVR_RETVM=") in new stack
67 [2023-01-22 22:15:11] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@ivr-1:5] GotoIf("SIP/in7XXXXXXXX5-0000000f", "0?skip") in new stack
68 [2023-01-22 22:15:11] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@ivr-1:6] Answer("SIP/in7XXXXXXXX5-0000000f", "") in new stack
69 [2023-01-22 22:15:11] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@ivr-1:7] Set("SIP/in7XXXXXXXX5-0000000f", "IVR_MSG=custom/ABM-Hello-voice") in new stack
70 [2023-01-22 22:15:11] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@ivr-1:8] Set("SIP/in7XXXXXXXX5-0000000f", "TIMEOUT(digit)=3") in new stack
71 [2023-01-22 22:15:11] VERBOSE[15749][C-0000000d] func_timeout.c: Digit timeout set to 3.000
72 [2023-01-22 22:15:11] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@ivr-1:9] ExecIf("SIP/in7XXXXXXXX5-0000000f", "1?Background(custom/ABM-Hello-voice)") in new stack
73 [2023-01-22 22:15:11] VERBOSE[15749][C-0000000d] file.c: <SIP/in7XXXXXXXX5-0000000f> Playing 'custom/ABM-Hello-voice.slin' (language 'ru')
74 [2023-01-22 22:15:22] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@ivr-1:10] WaitExten("SIP/in7XXXXXXXX5-0000000f", "5,") in new stack
75 [2023-01-22 22:15:27] VERBOSE[15749][C-0000000d] pbx_builtins.c: Timeout on SIP/in7XXXXXXXX5-0000000f, going to 't'
76 [2023-01-22 22:15:27] VERBOSE[15749][C-0000000d] pbx.c: Executing [t@ivr-1:1] Playback("SIP/in7XXXXXXXX5-0000000f", "no-valid-responce-transfering") in new stack
77 [2023-01-22 22:15:27] VERBOSE[15749][C-0000000d] file.c: <SIP/in7XXXXXXXX5-0000000f> Playing 'no-valid-responce-transfering.ulaw' (language 'ru')
78 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [t@ivr-1:2] Goto("SIP/in7XXXXXXXX5-0000000f", "ext-queues,200,1") in new stack
79 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx_builtins.c: Goto (ext-queues,200,1)
80 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [200@ext-queues:1] Macro("SIP/in7XXXXXXXX5-0000000f", "user-callerid,") in new stack
81 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:1] Set("SIP/in7XXXXXXXX5-0000000f", "TOUCH_MONITOR=1674425710.23") in new stack
82 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:2] Set("SIP/in7XXXXXXXX5-0000000f", "CHANCONTEXT=") in new stack
83 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:3] Set("SIP/in7XXXXXXXX5-0000000f", "CHANCONTEXT=") in new stack
84 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:4] Set("SIP/in7XXXXXXXX5-0000000f", "CHANEXTENCONTEXT=in7XXXXXXXX5-0000000f") in new stack
85 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:5] Set("SIP/in7XXXXXXXX5-0000000f", "CHANEXTEN=in7XXXXXXXX5-0000000f") in new stack
86 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:6] Set("SIP/in7XXXXXXXX5-0000000f", "CALLERID(number)=XXXXXXXX42") in new stack
87 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:7] Set("SIP/in7XXXXXXXX5-0000000f", "AMPUSER=XXXXXXXX42") in new stack
88 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:8] Set("SIP/in7XXXXXXXX5-0000000f", "HOTDESCKCHAN=in7XXXXXXXX5-0000000f") in new stack
89 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:9] Set("SIP/in7XXXXXXXX5-0000000f", "HOTDESKEXTEN=in7XXXXXXXX5") in new stack
90 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:10] Set("SIP/in7XXXXXXXX5-0000000f", "HOTDESKCALL=0") in new stack
91 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:11] ExecIf("SIP/in7XXXXXXXX5-0000000f", "0?Set(HOTDESKCALL=1)") in new stack
92 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:12] ExecIf("SIP/in7XXXXXXXX5-0000000f", "0?Set(CALLERID(name)=)") in new stack
93 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:13] GotoIf("SIP/in7XXXXXXXX5-0000000f", "0?report") in new stack
94 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:14] ExecIf("SIP/in7XXXXXXXX5-0000000f", "1?Set(REALCALLERIDNUM=XXXXXXXX42)") in new stack
95 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:15] Set("SIP/in7XXXXXXXX5-0000000f", "AMPUSER=") in new stack
96 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:16] GotoIf("SIP/in7XXXXXXXX5-0000000f", "0?limit") in new stack
97 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:17] Set("SIP/in7XXXXXXXX5-0000000f", "AMPUSERCIDNAME=") in new stack
98 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:18] ExecIf("SIP/in7XXXXXXXX5-0000000f", "0?Set(__CIDMASQUERADING=TRUE)") in new stack
99 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:19] GotoIf("SIP/in7XXXXXXXX5-0000000f", "1?report") in new stack
100 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx_builtins.c: Goto (macro-user-callerid,s,28)
101 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:28] NoOp("SIP/in7XXXXXXXX5-0000000f", "Macro Depth is 1") in new stack
102 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:29] GotoIf("SIP/in7XXXXXXXX5-0000000f", "1?report2:macroerror") in new stack
103 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx_builtins.c: Goto (macro-user-callerid,s,30)
104 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:30] GotoIf("SIP/in7XXXXXXXX5-0000000f", "0?continue") in new stack
105 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:31] ExecIf("SIP/in7XXXXXXXX5-0000000f", "1?Set(__CALLEE_ACCOUNCODE=)") in new stack
106 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:32] Set("SIP/in7XXXXXXXX5-0000000f", "__TTL=64") in new stack
107 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:33] GotoIf("SIP/in7XXXXXXXX5-0000000f", "1?continue") in new stack
108 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx_builtins.c: Goto (macro-user-callerid,s,49)
109 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:49] Set("SIP/in7XXXXXXXX5-0000000f", "CALLERID(number)=XXXXXXXX42") in new stack
110 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:50] Set("SIP/in7XXXXXXXX5-0000000f", "CALLERID(name)=XXXXXXXX42") in new stack
111 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:51] GotoIf("SIP/in7XXXXXXXX5-0000000f", "0?cnum") in new stack
112 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:52] Set("SIP/in7XXXXXXXX5-0000000f", "CDR(cnam)=XXXXXXXX42") in new stack
113 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:53] Set("SIP/in7XXXXXXXX5-0000000f", "CDR(cnum)=XXXXXXXX42") in new stack
114 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [s@macro-user-callerid:54] Set("SIP/in7XXXXXXXX5-0000000f", "CHANNEL(language)=ru") in new stack
115 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [200@ext-queues:2] Answer("SIP/in7XXXXXXXX5-0000000f", "") in new stack
116 [2023-01-22 22:15:32] VERBOSE[15749][C-0000000d] pbx.c: Executing [200@ext-queues:3] Set("SIP/in7XXXXXXXX5-0000000f", "__NODEST=200") in new stack
А потом ее распознать не получается.
А сейчас любой Входящий разговор завершается обрывом.
Исходщие вроде нормално.
Еще не слышит DTMF совсем.
Как решить проблему. Как дамп снять и как его прочитать и понять почему рвется и кто виноват?
Смотрел
Re: обрыв входящих на 31 секунде и не не работает прямой наб
1. Крайне неверно зачирикивать свои номера иксами.
Х - особый знак в шаблонах диалплана, как вы знаете, это цифры от 0 до 9.
Лучше бы маскировали каким то внятным кодом, хоть 71234567890, или по выбору.
И публичне адреса ИП - тоже глупо шифровать так, лучше изменили бы 1-2 цифры, зато было бы понятней - кто от кого.
2. Входящие на ИВР у вас приходят,
custom/hellohello - слышно вообще?
Ну и попадают как надо и куда надо:
ждёт ввода внутреннего номера WaitExten и отваливается, ничего не получив, по таймауту.
3. Для отладки в консоли включайте dtmf дебаг (не спрашивайте только тут - а где мне включить дебаг dtmf? - спросите у Гугла, он точно знает) и уточните у Зебры формат передаваемых тонов dtmf. Может быть в rfc2833, в info и inband. Хорошая практика - почитать про все три режима теорию чуть-чуть. Часто бывает непрохождение dtmf на стороне местного провайдера моб. связи, или его стыке с Зеброй и другими операторами связи.
4. Дамп снимать и исследовать нужно самостоятельно: открыть http://asterisk.ru, и там - База знаний, Отладка VoIP звонка c Wireshark.
Если всё это трудно, логи непонятны - добро пожаловать в раздел Бизнес данного форума. У всех свои запросы и уровни компетентности.
reabool
Сообщение reabool »
порт UDP - 5060 открыт.
порт TCP - 5060 открыт
порт TCP - 5161 открыт
порты TCP/UDP - 5061 открыты
порт UDP - 5160 открыт.
порты с 10000 по 20000 тоже открыты (хотя на другой атске в другой сети не открыты и работает)
custom/hellohello слышу отлично и если вызов направлть на единичный добавочный тоже го слышу отлично. Но независимо от результата. Снял ли абонент трубку, не снял. Говорили мы или нет. любой входящий заканчивается ровно через 30 секунд от снятия трубки АТСкой. т.е.
Например я набрал номер с мобильного или с другой АТС пошел вызов 0 сек - слышу HelloHello приветствие - набираю добавочный - Слышу что набора не получили - вызов пошел на добавочный указанный в IVR например или Очереди - снимаю трубку совтфона (или не снимаю) 31сек. вызов завершен.
Почему стабильно 30 ?! не 20 не 45 не 98 это вопрос
DTMF меня пока меньше интересует.
reabool писал(а):Почему стабильно 30 ?! не 20 не 45 не 98 это вопрос
Потому что таймаут мониторинга зависших соединений = 30 сек.
Из-за того, что вы используете оба канала - chan_sip & pjsip, и в голове каша от использования портов TCP/UDP и происходят такие удивительные вещи. Трубки абонентов отвечают не в тот канал сигнализации, и RTCP гасит разговор, считая, что там нет RTP от слова совсем.
https://community.freepbx.org/t/inbound ... -bye/58917
Вам надо уже в платный суппорт. И/или на техучёбу. В рамках форума индивидуальное обучение по переписке не практикуется.
ТС, дублировать темы не есть хорошо...
Почему прячьте настройки пира?
Телепаты видимо Вам помогают)
А так стандартно всё, directmedia=no небось не поставлено, да на непонятной модели роутере SIP ALG скорее всего включен..
Даже не интересно как-то писать в 1001000 раз..
reabool
Сообщение reabool »
Спасибо всем за осветы.
Относительно дублирования.
Я тут был последний раз на форуме давно когда в прошлый раз настраивал примерно такую же Freepbx. И по этому завел тему а в конце у меня уведомление о том, что тема будет проверена Администратором не прогрузилось. только кнопка без названия. Я нажал на нее и ни темы ничего. Я подумал, что не получилось разместить и через некоторое время оформил тему еще раз. Даже на этот раз как-то больше данных постарался добавить в силу своих познаний, что мог рассказать)) А уважаемая администрация форума взяла и разместила обе. За что спасибо еще раз. Но прошу другую тему если можно удалить, что бы не плодить дубликаты и вообще сам понимаю, что как то не то.
Относительно настроек. Я настраиваю второй раз FreePBC в соответствии с рекомендациями производителя так сказать.
1. про проброс портов 10000 - 20000 Я их конечно пробросил на роутере, но не до конца понимаю. Попробую доки покурить на эту тему.
(Но мысль у меня такая , что это же для внешних клиентов, насколько я понял. А у меня все клиенты за NATом внутри напрямую сервер видят?! )
2. Pjsip я отключал в пункте меню: FreePBX Advanced Settings - План набора (диал-план) и функциональность - SIP Channel Driver - стоит "chan_sip" и все.
А в "Настройка SIP" - активна вкладка только (These settings apply only to SIP Legacy [chan_sip] )
3. Мой общедоступный IP-адрес совпадает с тем, что есть в настройках SIP Asterisk -> внешний адрес. (хотя стоял некоторое время назад ошибочный и может надо было не просто применить, а перезагрузить даже. Сечас сделаю)
4. Настройки пиров пока не разобрался где посмотреть но в /etc/asterisk/sip.conf висит гордая надпись
"Do NOT edit this file as it is auto-generated by FreePBX. All modifications to ;
; this file must be done via the web gui. There are alternative files to make ;
; custom modifications.
" Сейчас разберусь где находится файл с настройками и покажу. Не скрываю. Подозреваю. что тут в разных может файлах быть.
Не все знаю. что может пригодиться. Избыточная информация тоже не полезна тут.
5. directmedia=no . никак не найду, но найду наверно Это для NAT. Уведомление о NAT у меня включено .
Вообще ситуация такая: Исходящие на мобильный с внутренних есть . Звук прекрасный в обе стороны. А входящие, что то когда как. В основном не слышат тдуг друга. А иногда Слышно всем, но 30 сек. Т.е. набрал с города атс - 6сек приветствие - вызов ушел внурть - ктото снял трубку и если слышно то секунт 15 разговора и все. Итого у звонящего тайминг от первого слова приветствия до разрыва всегда 30 сек. Если никто не снял тоже 30 сек и если снял и не слышно тоже 30 сек. (бред какойто)
И да. Некоторые абоненты подключены в порт 5060, а некоторые в 5062 Наверно 5062 не правильно чтоли?!
Name/username Host Dyn Forcerport Comedia ACL Port Status Description
101/101 192.168.1.82 D Yes Yes A 5060 OK (9 ms)
102/102 192.168.1.106 D Yes Yes A 5060 OK (9 ms)
104/104 192.168.1.111 D Yes Yes A 5060 OK (9 ms)
106/106 192.168.1.94 D Yes Yes A 5060 OK (8 ms)
107/107 192.168.1.112 D Yes Yes A 5060 OK (8 ms)
108/108 192.168.1.98 D Yes Yes A 5060 OK (15 ms)
120/120 192.168.1.60 D Yes Yes A 5062 OK (7 ms)
121/121 192.168.1.61 D Yes Yes A 5062 OK (7 ms)
122/122 192.168.1.69 D Yes Yes A 5062 OK (10 ms)
123/123 192.168.1.79 D Yes Yes A 5062 OK (8 ms)
124/124 192.168.1.81 D Yes Yes A 5062 OK (7 ms)
in74951234567/11111111 222.111.333.888 Yes Yes 5060 OK (9 ms)
out74951234567/11111111 222.111.333.888 Yes Yes 5060 OK (8 ms)
(Класс, что тут нормально хоть спойлер работает. то на другом форуме по другому вопросу о Linux/ голову свернул на тему логов там выложить или че то такого
и просьба.
Если нет желания оказать помощь, большая просьба не троллить меня, я без вас справляюсь. Разбираюсь по мере сил и четам в голове на эту тему.
reabool
Сообщение reabool »
Вот выключил/включил (не перезагрузил в смысле.
Но перед этим во встроенных логах тоже краснота какая то. :-(
[2023-01-25 17:35:36] WARNING[2290] loader.c: Module 'res_monitor' has been loaded but was deprecated in Asterisk version 16 and will be removed in Asterisk version 21. Its replacement is 'app_mixmonitor'.
9704 [2023-01-25 17:35:36] WARNING[2290] loader.c: Module 'chan_sip' has been loaded but was deprecated in Asterisk version 17 and will be removed in Asterisk version 21.
9705 [2023-01-25 17:35:36] WARNING[2290] loader.c: Module 'res_adsi' has been loaded but may be removed in a future release.
9706 [2023-01-25 17:35:36] WARNING[2290] loader.c: Module 'app_meetme' has been loaded but will be deprecated in Asterisk version 19 and will be removed in Asterisk version 21. Its replacement is 'app_confbridge'.
9707 [2023-01-25 17:35:36] WARNING[2290] loader.c: Module 'app_adsiprog' has been loaded but may be removed in a future release.
9708 [2023-01-25 17:35:36] WARNING[2290] loader.c: Module 'app_url' has been loaded but was deprecated in Asterisk version 16 and will be removed in Asterisk version 19.
9709 [2023-01-25 17:35:36] WARNING[2290] loader.c: Module 'app_getcpeid' has been loaded but may be removed in a future release.
9710 [2023-01-25 17:35:36] WARNING[2290] loader.c: Module 'app_ices' has been loaded but was deprecated in Asterisk version 16 and will be removed in Asterisk version 19.
9711 [2023-01-25 17:35:36] WARNING[2290] loader.c: Module 'app_image' has been loaded but was deprecated in Asterisk version 16 and will be removed in Asterisk version 19.
9712 [2023-01-25 17:35:36] WARNING[2290] loader.c: Module 'app_macro' has been loaded but was deprecated in Asterisk version 16 and will be removed in Asterisk version 21. Its replacement is 'app_stack (GoSub)'.
9713 [2023-01-25 17:35:36] WARNING[2290] loader.c: Module 'app_nbscat' has been loaded but was deprecated in Asterisk version 16 and will be removed in Asterisk version 19.
9714 [2023-01-25 17:35:36] WARNING[2290] loader.c: Module 'app_mysql' has been loaded but was deprecated in Asterisk version 1.8 and will be removed in Asterisk version 19. Its replacement is 'func_odbc'.
9715 [2023-01-25 17:35:36] WARNING[2290] loader.c: Module 'app_dahdiras' has been loaded but was deprecated in Asterisk version 16 and will be removed in Asterisk version 19.
9716 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'chan_local.so': /usr/lib64/asterisk/modules/chan_local.so: cannot open shared object file: No such file or directory
9717 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'func_pjsip_aor.so', missing dependency: res_pjsip
9718 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'func_pjsip_contact.so', missing dependency: res_pjsip
9719 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_hep_pjsip.so', missing dependencies: res_pjsip, res_pjsip_session
9720 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_pjsip_xpidf_body_generator.so', missing dependencies: res_pjsip, res_pjsip_pubsub
9721 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_prometheus.so', missing dependency: res_pjsip
9722 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_pjsip_pidf_eyebeam_body_supplement.so', missing dependencies: res_pjsip, res_pjsip_pubsub
9723 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_pjsip_dialog_info_body_generator.so', missing dependencies: res_pjsip, res_pjsip_pubsub
9724 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_pjsip_dlg_options.so', missing dependencies: res_pjsip, res_pjsip_session
9725 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_pjsip_empty_info.so', missing dependencies: res_pjsip, res_pjsip_session
9726 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_pjsip_publish_asterisk.so', missing dependencies: res_pjsip, res_pjsip_outbound_publish, res_pjsip_pubsub
9727 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_pjsip_history.so', missing dependency: res_pjsip
9728 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_pjsip_send_to_voicemail.so', missing dependencies: res_pjsip, res_pjsip_session
9729 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_pjsip_mwi_body_generator.so', missing dependencies: res_pjsip, res_pjsip_pubsub
9730 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_pjsip_sips_contact.so', missing dependency: res_pjsip
9731 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_pjsip_stir_shaken.so', missing dependencies: res_pjsip, res_pjsip_session
9732 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_pjsip_path.so', missing dependencies: res_pjsip, res_pjsip_session
9733 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_pjsip_phoneprov_provider.so', missing dependencies: res_pjsip, res_phoneprov
9734 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_pjsip_pidf_body_generator.so', missing dependencies: res_pjsip, res_pjsip_pubsub
9735 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_pjsip_pidf_digium_body_supplement.so', missing dependencies: res_pjsip, res_pjsip_pubsub
9736 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_pjsip_callid.so', missing dependencies: res_pjsip, res_pjsip_session
9737 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_pjsip_send_info.so', missing dependencies: res_pjsip, res_pjsip_session
9738 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_pjsip_aoc.so': /usr/lib64/asterisk/modules/res_pjsip_aoc.so: undefined symbol: pjsip_media_type_multipart_mixed
9739 [2023-01-25 17:35:36] ERROR[2290] loader.c: Error loading module 'res_pjsip_rfc3329.so', missing dependencies: res_pjsip, res_pjsip_session
9740 [2023-01-25 17:35:36] ERROR[2290] loader.c: res_config_sqlite declined to load.
9741 [2023-01-25 17:35:36] ERROR[2290] loader.c: res_xmpp declined to load.
9742 [2023-01-25 17:35:36] ERROR[2290] loader.c: Declined modules which depend on res_xmpp: chan_motif
9743 [2023-01-25 17:35:36] ERROR[2290] loader.c: res_stun_monitor declined to load.
9744 [2023-01-25 17:35:36] ERROR[2290] loader.c: chan_console declined to load.
9745 [2023-01-25 17:35:36] ERROR[2290] loader.c: chan_skinny declined to load.
9746 [2023-01-25 17:35:36] ERROR[2290] loader.c: chan_ooh323 declined to load.
9747 [2023-01-25 17:35:36] ERROR[2290] loader.c: chan_mobile declined to load.
9748 [2023-01-25 17:35:36] ERROR[2290] loader.c: res_hep declined to load.
9749 [2023-01-25 17:35:36] ERROR[2290] loader.c: Declined modules which depend on res_hep: res_hep_rtcp
9750 [2023-01-25 17:35:36] ERROR[2290] loader.c: app_agent_pool declined to load.
9751 [2023-01-25 17:35:36] ERROR[2290] loader.c: res_calendar declined to load.
9752 [2023-01-25 17:35:36] ERROR[2290] loader.c: Declined modules which depend on res_calendar: res_calendar_caldav, res_calendar_ews, res_calendar_exchange, res_calendar_icalendar
9753 [2023-01-25 17:35:36] ERROR[2290] loader.c: cdr_csv declined to load.
9754 [2023-01-25 17:35:36] ERROR[2290] loader.c: cdr_odbc declined to load.
9755 [2023-01-25 17:35:36] ERROR[2290] loader.c: app_alarmreceiver declined to load.
9756 [2023-01-25 17:35:36] ERROR[2290] loader.c: app_festival declined to load.
9757 [2023-01-25 17:35:36] ERROR[2290] loader.c: app_followme declined to load.
9758 [2023-01-25 17:35:36] ERROR[2290] loader.c: chan_phone declined to load.
9759 [2023-01-25 17:35:36] ERROR[2290] loader.c: chan_unistim declined to load.
9760 [2023-01-25 17:35:36] ERROR[2290] loader.c: pbx_dundi declined to load.
9761 [2023-01-25 17:35:36] ERROR[2290] loader.c: pbx_lua declined to load.
9762 [2023-01-25 17:35:36] ERROR[2290] loader.c: pbx_ael declined to load.
9763 [2023-01-25 17:35:36] ERROR[2290] loader.c: res_pktccops declined to load.
9764 [2023-01-25 17:35:36] ERROR[2290] loader.c: func_odbc declined to load.
9765 [2023-01-25 17:35:36] WARNING[2293] chan_sip.c: chan_sip has no official maintainer and is deprecated. Migration to
9766 [2023-01-25 17:35:36] WARNING[2293] chan_sip.c: chan_pjsip is recommended. See guides at the Asterisk Wiki:
9767 [2023-01-25 17:35:36] WARNING[2293] chan_sip.c: https://wiki.asterisk.org/wiki/display/ ... +res_pjsip
9768 [2023-01-25 17:35:36] WARNING[2293] chan_sip.c: https://wiki.asterisk.org/wiki/display/ ... +res_pjsip
9769 [2023-01-25 17:35:36] VERBOSE[2290] asterisk.c: Asterisk Ready.
reabool
Сообщение reabool »
/etc/asterisk/modules.conf
; Do NOT edit this file as it is auto-generated by FreePBX. ;
; For information on adding additional paramaters to this file, please visit the ;
; FreePBX.org wiki page, or ask on IRC. This file was created by the new FreePBX ;
; BMO - Big Module Object. Any similarity in naming with BMO from Adventure Time ;
; is totally deliberate. ;
[modules]
autoload=yes
preload = pbx_config.so
preload = chan_local.so
preload = func_db.so
preload = res_odbc.so
preload = res_config_odbc.so
preload = cdr_adaptive_odbc.so
noload = chan_woomera.so
noload = pbx_gtkconsole.so
noload = pbx_kdeconsole.so
noload = app_intercom.so
noload = chan_modem.so
noload = chan_modem_bestdata.so
noload = chan_modem_i4l.so
noload = app_trunkisavail.so
noload = chan_alsa.so
noload = chan_oss.so
noload = app_directory_odbcstorage.so
noload = app_voicemail_odbcstorage.so
noload = chan_modem_aopen.so
noload = cdr_radius.so
noload = cel_radius.so
noload = cdr_mysql.so
noload = res_phoneprov.so
noload = res_config_ldap.so
noload = res_config_sqlite3.so
noload = res_clialiases.so
noload = chan_mgcp.so
noload = cdr_custom.so
noload = app_minivm.so
noload = cel_custom.so
noload = chan_pjsip.so
noload = res_pjsip_endpoint_identifier_anonymous.so
noload = res_pjsip_messaging.so
noload = res_pjsip_pidf.so
noload = res_pjsip_session.so
noload = func_pjsip_endpoint.so
noload = res_pjsip_endpoint_identifier_ip.so
noload = res_pjsip_mwi.so
noload = res_pjsip_pubsub.so
noload = res_pjsip.so
noload = res_pjsip_acl.so
noload = res_pjsip_endpoint_identifier_user.so
noload = res_pjsip_nat.so
noload = res_pjsip_refer.so
noload = res_pjsip_t38.so
noload = res_pjsip_authenticator_digest.so
noload = res_pjsip_exten_state.so
noload = res_pjsip_notify.so
noload = res_pjsip_registrar_expire.so
noload = res_pjsip_transport_websocket.so
noload = res_pjsip_caller_id.so
noload = res_pjsip_header_funcs.so
noload = res_pjsip_one_touch_record_info.so
noload = res_pjsip_registrar.so
noload = res_pjsip_diversion.so
noload = res_pjsip_log_forwarder.so
noload = res_pjsip_outbound_authenticator_digest.so
noload = res_pjsip_rfc3326.so
noload = res_pjsip_dtmf_info.so
noload = res_pjsip_logger.so
noload = res_pjsip_outbound_registration.so
noload = res_pjsip_sdp_rtp.so
noload = res_pjsip_outbound_publish.so
noload = res_pjsip_config_wizard.so
load = format_wav.so
load = format_pcm.so
load = format_mp3.so
load = res_musiconhold.so
Во время загрузки у меня так:
18249 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'chan_local.so': /usr/lib64/asterisk/modules/chan_local.so: cannot open shared object file: No such file or directory
18250 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'func_pjsip_aor.so', missing dependency: res_pjsip
18251 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'func_pjsip_contact.so', missing dependency: res_pjsip
18252 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_hep_pjsip.so', missing dependencies: res_pjsip, res_pjsip_session
18253 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_pjsip_xpidf_body_generator.so', missing dependencies: res_pjsip, res_pjsip_pubsub
18254 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_prometheus.so', missing dependency: res_pjsip
18255 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_pjsip_pidf_eyebeam_body_supplement.so', missing dependencies: res_pjsip, res_pjsip_pubsub
18256 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_pjsip_dialog_info_body_generator.so', missing dependencies: res_pjsip, res_pjsip_pubsub
18257 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_pjsip_dlg_options.so', missing dependencies: res_pjsip, res_pjsip_session
18258 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_pjsip_empty_info.so', missing dependencies: res_pjsip, res_pjsip_session
18259 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_pjsip_publish_asterisk.so', missing dependencies: res_pjsip, res_pjsip_outbound_publish, res_pjsip_pubsub
18260 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_pjsip_history.so', missing dependency: res_pjsip
18261 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_pjsip_send_to_voicemail.so', missing dependencies: res_pjsip, res_pjsip_session
18262 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_pjsip_mwi_body_generator.so', missing dependencies: res_pjsip, res_pjsip_pubsub
18263 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_pjsip_sips_contact.so', missing dependency: res_pjsip
18264 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_pjsip_stir_shaken.so', missing dependencies: res_pjsip, res_pjsip_session
18265 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_pjsip_path.so', missing dependencies: res_pjsip, res_pjsip_session
18266 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_pjsip_phoneprov_provider.so', missing dependencies: res_pjsip, res_phoneprov
18267 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_pjsip_pidf_body_generator.so', missing dependencies: res_pjsip, res_pjsip_pubsub
18268 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_pjsip_pidf_digium_body_supplement.so', missing dependencies: res_pjsip, res_pjsip_pubsub
18269 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_pjsip_callid.so', missing dependencies: res_pjsip, res_pjsip_session
18270 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_pjsip_send_info.so', missing dependencies: res_pjsip, res_pjsip_session
18271 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_pjsip_aoc.so': /usr/lib64/asterisk/modules/res_pjsip_aoc.so: undefined symbol: pjsip_media_type_multipart_mixed
18272 [2023-01-25 19:10:49] ERROR[2293] loader.c: Error loading module 'res_pjsip_rfc3329.so', missing dependencies: res_pjsip, res_pjsip_session
18273 [2023-01-25 19:10:49] ERROR[2293] loader.c: res_config_sqlite declined to load.
18274 [2023-01-25 19:10:49] ERROR[2293] loader.c: res_xmpp declined to load.
18275 [2023-01-25 19:10:49] ERROR[2293] loader.c: Declined modules which depend on res_xmpp: chan_motif
18276 [2023-01-25 19:10:49] ERROR[2293] loader.c: res_stun_monitor declined to load.
18277 [2023-01-25 19:10:49] ERROR[2293] loader.c: chan_console declined to load.
18278 [2023-01-25 19:10:49] ERROR[2293] loader.c: chan_skinny declined to load.
18279 [2023-01-25 19:10:49] ERROR[2293] loader.c: chan_ooh323 declined to load.
18280 [2023-01-25 19:10:49] ERROR[2293] loader.c: chan_mobile declined to load.
18281 [2023-01-25 19:10:49] ERROR[2293] loader.c: res_hep declined to load.
18282 [2023-01-25 19:10:49] ERROR[2293] loader.c: Declined modules which depend on res_hep: res_hep_rtcp
18283 [2023-01-25 19:10:49] ERROR[2293] loader.c: app_agent_pool declined to load.
18284 [2023-01-25 19:10:49] ERROR[2293] loader.c: res_calendar declined to load.
18285 [2023-01-25 19:10:49] ERROR[2293] loader.c: Declined modules which depend on res_calendar: res_calendar_caldav, res_calendar_ews, res_calendar_exchange, res_calendar_icalendar
18286 [2023-01-25 19:10:49] ERROR[2293] loader.c: cdr_csv declined to load.
18287 [2023-01-25 19:10:49] ERROR[2293] loader.c: cdr_odbc declined to load.
18288 [2023-01-25 19:10:49] ERROR[2293] loader.c: app_alarmreceiver declined to load.
18289 [2023-01-25 19:10:49] ERROR[2293] loader.c: app_festival declined to load.
18290 [2023-01-25 19:10:49] ERROR[2293] loader.c: app_followme declined to load.
18291 [2023-01-25 19:10:49] ERROR[2293] loader.c: chan_phone declined to load.
18292 [2023-01-25 19:10:49] ERROR[2293] loader.c: chan_unistim declined to load.
18293 [2023-01-25 19:10:49] ERROR[2293] loader.c: pbx_dundi declined to load.
18294 [2023-01-25 19:10:49] ERROR[2293] loader.c: pbx_lua declined to load.
18295 [2023-01-25 19:10:49] ERROR[2293] loader.c: pbx_ael declined to load.
18296 [2023-01-25 19:10:49] ERROR[2293] loader.c: res_pktccops declined to load.
18297 [2023-01-25 19:10:49] ERROR[2293] loader.c: func_odbc declined to load.
18298 [2023-01-25 19:10:49] VERBOSE[2293] asterisk.c: Asterisk Ready.
18299 [2023-01-25 19:10:49] WARNING[2296] chan_sip.c: chan_sip has no official maintainer and is deprecated. Migration to
18300 [2023-01-25 19:10:49] WARNING[2296] chan_sip.c: chan_pjsip is recommended. See guides at the Asterisk Wiki:
18301 [2023-01-25 19:10:49] WARNING[2296] chan_sip.c: https://wiki.asterisk.org/wiki/display/ ... +res_pjsip
как отключить pjsip ?
Если autoload=yes
то
указывать не надо.
Загружаются все модули из директории /usr/lib/asterisk/modules кроме указанных как noload.
reabool писал(а):1. про проброс портов 10000 - 20000 Я их конечно пробросил на роутере, но не до конца понимаю. Попробую доки покурить на эту тему.
Нет единой схемы подключения к провадйру телефонии из-за НАТа. Потому что провайдеры разные, и НАТообразующие устройства разные, и многое другое. В простой схеме - у провайдера надо зарегистрироваться по sip, типа
register => 79012345678:sUpErSeCrEt@sbc.megafon.ru/79012345678
и тогда запрос регистрации проходит через трансляцию НАТ по верхним портам, оборудование провайдера видит вашу АТС на (условном)
122.23.34.56:14392 - туда и шлёт инвайт входящего к вам звонка. Но может быть статический транк без регистрации, о публичном адресе своей АТС вы договариваетесь заранее, и тогда куда им слать инвайт? На какой порт? Вот тогда пропиливается статическая трансляция, симметричный проброс портов UDP:
122.23.34.56:5060 = 192.168.0.60:5060
122.23.34.56:10000-20000 = 192.168.0.60:10000-20000
В общем это азбука, которую вам надо вспоминать, а вы читать не очень, лучше общаться, верно?
Доки курить - это правильно. Порты 5060 и 5062 - это порты ИП телефонов, а не порты станции, и они могут быть любые.
