Подскажите что не так
Diesel.spb
Сообщение Diesel.spb »
Гуру подскажите что не так в лог файле..
Что смущает и на что нужно обратить внимание?!!
[2013-08-16 16:00:43] WARNING[1372]: chan_sip.c:20245 handle_response_invite: Received response: "Forbidden" from '"1919" <sip:1919@192.168.0.111>;tag=as7f8a98be'
Scheduling destruction of SIP dialog '7b146ff6418b9078379a990e49dbe2a4@192.168.0.111:5060' in 6400 ms (Method: INVITE)
    -- Executing [s@macro-dialout-trunk:23] NoOp("SIP/1919-0000034a", "Dial failed for some reason with DIALSTATUS = CONGESTION and HANGUPCAUSE = 34") in new stack
    -- Executing [s@macro-dialout-trunk:24] Goto("SIP/1919-0000034a", "s-CONGESTION,1") in new stack
    -- Goto (macro-dialout-trunk,s-CONGESTION,1)
    -- Executing [s-CONGESTION@macro-dialout-trunk:1] Set("SIP/1919-0000034a", "RC=34") in new stack
    -- Executing [s-CONGESTION@macro-dialout-trunk:2] Goto("SIP/1919-0000034a", "34,1") in new stack
    -- Goto (macro-dialout-trunk,34,1)
    -- Executing [34@macro-dialout-trunk:1] Goto("SIP/1919-0000034a", "continue,1") in new stack
    -- Executing [continue@macro-dialout-trunk:1] GotoIf("SIP/1919-0000034a", "1?noreport") in new stack
    -- Goto (macro-dialout-trunk,continue,3)
    -- Executing [continue@macro-dialout-trunk:3] NoOp("SIP/1919-0000034a", "TRUNK Dial failed due to CONGESTION HANGUPCAUSE: 34 - failing through to other trunks") in new stack
    -- Executing [continue@macro-dialout-trunk:4] Set("SIP/1919-0000034a", "CALLERID(number)=1919") in new stack
    -- Executing [2100@from-internal:7] Macro("SIP/1919-0000034a", "outisbusy,") in new stack
    -- Executing [s@macro-outisbusy:1] Progress("SIP/1919-0000034a", "") in new stack
    -- Executing [s@macro-outisbusy:2] GotoIf("SIP/1919-0000034a", "0?emergency,1") in new stack
    -- Executing [s@macro-outisbusy:3] GotoIf("SIP/1919-0000034a", "1?intracompany,1") in new stack
    -- Goto (macro-outisbusy,intracompany,1)
    -- Executing [intracompany@macro-outisbusy:1] Playback("SIP/1919-0000034a", "all-circuits-busy-now&pls-try-call-later, noanswer") in new stack
[2013-08-16 16:00:43] WARNING[28303]: file.c:663 ast_openstream_full: File all-circuits-busy-now does not exist in any format
[2013-08-16 16:00:43] WARNING[28303]: file.c:958 ast_streamfile: Unable to open all-circuits-busy-now (format 0x4 (ulaw)): No such file or directory
[2013-08-16 16:00:43] WARNING[28303]: app_playback.c:475 playback_exec: ast_streamfile failed on SIP/1919-0000034a for all-circuits-busy-now&pls-try-call-later, noanswer
[2013-08-16 16:00:43] WARNING[28303]: file.c:663 ast_openstream_full: File pls-try-call-later does not exist in any format
[2013-08-16 16:00:43] WARNING[28303]: file.c:958 ast_streamfile: Unable to open pls-try-call-later (format 0x4 (ulaw)): No such file or directory
    -- Executing [intracompany@macro-outisbusy:2] Congestion("SIP/1919-0000034a", "20") in new stack
  == Spawn extension (macro-outisbusy, intracompany, 2) exited non-zero on 'SIP/1919-0000034a' in macro 'outisbusy'
  == Spawn extension (from-internal, 2100, 7) exited non-zero on 'SIP/1919-0000034a'
    -- Executing [h@from-internal:1] Hangup("SIP/1919-0000034a", "") in new stack
  == Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/1919-0000034a'
Really destroying SIP dialog '00001043-c2f67bde3efd100089ec0080f0bd07d4@192.168.99.220' Method: ACK
Really destroying SIP dialog '7b146ff6418b9078379a990e49dbe2a4@192.168.0.111:5060' Method: INVITE
Re: Подскажите что не так
переведите в alaw или ulaw формат все фразы - делом на 10 минут
Diesel.spb
не скромный вопрос как правильно перевести в др. формат
поиск - asterisk sox
Diesel.spb
ok понял спасибо
