Первый ивайт
<--- SIP read from UDP:192.168.0.2:5061 --->
INVITE sip:1001@192.168.0.1;transport=UDP SIP/2.0
Via: SIP/2.0/UDP 192.168.0.2:5061;branch=z9hG4bK-d8754z-2a6f6c9c2c2ba030-1---d8754z-
Contact: <sip:1000@192.168.0.2:5061;transport=UDP>
To: <sip:1001@192.168.0.1;transport=UDP>
From: "From Fax"<sip:1000@192.168.0.1;transport=UDP>;tag=4a328950
Call-ID: NmVlMDkwMTk2MzAwOWYwZDA1YmIwZDU1MzgzNzNlZmI.
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, BYE, NOTIFY, REFER, MESSAGE, OPTIONS, INFO, SUBSCRIBE
Supported: replaces, norefersub, extended-refer, X-cisco-serviceuri
User-Agent: Zoiper Communicator 2.05.11136 rev.11135
Allow-Events: presence, kpml
Content-Length: 208
v=0
o=Z 0 0 IN IP4 192.168.0.2
s=Z
c=IN IP4 192.168.0.2
t=0 0
m=audio 15000 RTP/AVP 8 0 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=fmtp:101 0-15
a=sendrecv
--- (14 headers 11 lines) ---
Sending to 192.168.0.2:5061 (no NAT)
Using INVITE request as basis request - NmVlMDkwMTk2MzAwOWYwZDA1YmIwZDU1MzgzNzNlZmI.
Found peer '1000' for '1000' from 192.168.0.2:5061
Found RTP audio format 8
Found RTP audio format 0
Found RTP audio format 101
Capabilities: us - (ulaw|alaw|g729), peer - audio=(ulaw|alaw)/video=(nothing)/text=(nothing), combined - (ulaw|alaw)
Peer audio RTP is at port 192.168.0.2:15000
Looking for 1001 in from-internal (domain 192.168.0.1)
list_route: hop: <sip:1000@192.168.0.2:5061;transport=UDP>
<--- Transmitting (no NAT) to 192.168.0.2:5061 --->
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.0.2:5061;branch=z9hG4bK-d8754z-2a6f6c9c2c2ba030-1---d8754z-;received=192.168.0.2
CSeq: 1 INVITE
Server: FPBX-2.11.0(11.0.0)
Contact: <sip:1001@192.168.0.1:5060>
SIP/2.0 180 Ringing
To: <sip:1001@192.168.0.1;transport=UDP>;tag=as302a27bb
CSeq: 1 INVITE
Remote-Party-ID: "Shcherbakov Alexey" <sip:1001@192.168.0.1>;party=called;privacy=off;screen=no
Audio is at 18358
Adding codec 100003 (ulaw) to SDP
<--- Reliably Transmitting (no NAT) to 192.168.0.2:5061 --->
SIP/2.0 200 OK
CSeq: 1 INVITE
Content-Length: 290
v=0
o=root 1043065622 1043065622 IN IP4 192.168.0.1
s=Asterisk PBX 11.0.0-rc1
c=IN IP4 192.168.0.1
t=0 0
m=audio 18358 RTP/AVP 8 0 101
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
ACK sip:1001@192.168.0.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.2:5061;branch=z9hG4bK-d8754z-6d68fd25ab83e0e9-1---d8754z-
CSeq: 1 ACK
--- (10 headers 0 lines) ---
Пришел второй инвайт
asterisk*CLI>
INVITE sip:1001@192.168.0.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.2:5061;branch=z9hG4bK-d8754z-5dd87589f636b6ac-1---d8754z-
CSeq: 2 INVITE
Content-Length: 208
v=0
o=Z 0 1 IN IP4 192.168.0.2
s=Z
t=0 0
a=fmtp:101 0-15
a=inactive
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.0.2:5061;branch=z9hG4bK-d8754z-5dd87589f636b6ac-1---d8754z-;received=192.168.0.2
CSeq: 2 INVITE
Audio is at 18358
SIP/2.0 200 OK
CSeq: 2 INVITE
Content-Length: 290
v=0
o=root 1043065622 1043065623 IN IP4 192.168.0.1
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=inactive
Via: SIP/2.0/UDP 192.168.0.2:5061;branch=z9hG4bK-d8754z-35cc1445234ab9c3-1---d8754z-
From: "From Fax"<sip:1000@192.168.0.1;transport=UDP>;tag=f7352e7f
Call-ID: ODNmYTZlZTI0YmQyYjczOGIwMmZkNzM2NTFjODk2YmM.
CSeq: 1 INVITE
Content-Length: 208
v=0
s=Z
t=0 0
m=audio 15002 RTP/AVP 8 0 101
a=fmtp:101 0-15
a=sendrecv
Using INVITE request as basis request - ODNmYTZlZTI0YmQyYjczOGIwMmZkNzM2NTFjODk2YmM.
Peer audio RTP is at port 192.168.0.2:15002
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.0.2:5061;branch=z9hG4bK-d8754z-35cc1445234ab9c3-1---d8754z-;received=192.168.0.2
CSeq: 1 INVITE
Via: SIP/2.0/UDP 192.168.0.2:5061;branch=z9hG4bK-d8754z-f288130d0dd3d603-1---d8754z-
CSeq: 2 ACK
CANCEL sip:1001@192.168.0.1;transport=UDP SIP/2.0
CSeq: 1 CANCEL
--- (9 headers 0 lines) ---
To: <sip:1001@192.168.0.1;transport=UDP>;tag=as3faf455c
CSeq: 1 INVITE
SIP/2.0 200 OK
CSeq: 1 CANCEL
ACK sip:1001@192.168.0.1;transport=UDP SIP/2.0
CSeq: 1 ACK
--- (8 headers 0 lines) ---
Really destroying SIP dialog 'ODNmYTZlZTI0YmQyYjczOGIwMmZkNzM2NTFjODk2YmM.' Method: ACK
Scheduling destruction of SIP dialog 'NmVlMDkwMTk2MzAwOWYwZDA1YmIwZDU1MzgzNzNlZmI.' in 6400 ms (Method: ACK)
set_destination: Parsing <sip:1000@192.168.0.2:5061;transport=UDP> for address/port to send to
set_destination: set destination to 192.168.0.2:5061
Reliably Transmitting (no NAT) to 192.168.0.2:5061:
BYE sip:1000@192.168.0.2:5061;transport=UDP SIP/2.0
Via: SIP/2.0/UDP 192.168.0.1:5060;branch=z9hG4bK100e9d66
From: <sip:1001@192.168.0.1;transport=UDP>;tag=as302a27bb
To: "From Fax"<sip:1000@192.168.0.1;transport=UDP>;tag=4a328950
CSeq: 102 BYE
User-Agent: FPBX-2.11.0(11.0.0)
SIP/2.0 200 OK
CSeq: 102 BYE
SIP Response message for INCOMING dialog BYE arrived
Really destroying SIP dialog 'NmVlMDkwMTk2MzAwOWYwZDA1YmIwZDU1MzgzNzNlZmI.' Method: ACK
asterisk*CLI> sip set debug off
SIP Debugging Disabled
asterisk*CLI>
