Проблема такова модем E173 работает нормально проблем нет проблемы ч E1550 вызов на него есть и на sip номер отправляется входящий но как только я поднимаю трубку на sip клиенте проходит около секунды и модем просто
-- Executing [+79255336559@from-pstn:1] NoOp("Dongle/MTS2-0100000004", "Catch-All DID Match - Found +79255336559 - You probably want a DID for this.") in new stack
-- Executing [+79255336559@from-pstn:2] Set("Dongle/MTS2-0100000004", "__FROM_DID=+79255336559") in new stack
-- Executing [+79255336559@from-pstn:3] Goto("Dongle/MTS2-0100000004", "ext-did,s,1") in new stack
-- Goto (ext-did,s,1)
> [INSERT INTO cel (eventtype,eventtime,cid_name,cid_num,cid_ani,cid_rdnis,cid_dnid,exten,context,channame,appname,appdata,amaflags,accountcode,uniqueid,linkedid,peer,userdeftype,userfield) VALUES ('CHAN_START',{ts '2014-05-05 00:25:06'},'MTS2','+79032478614','','','','+79255336559','from-pstn','Dongle/MTS2-0100000004','','',3,'','1399235106.16','1399235106.16','','','')]
-- Executing [s@ext-did:1] ExecIf("Dongle/MTS2-0100000004", "0?Set(__FROM_DID=s)") in new stack
-- Executing [s@ext-did:2] Gosub("Dongle/MTS2-0100000004", "app-blacklist-check,s,1()") in new stack
-- Executing [s@app-blacklist-check:1] GotoIf("Dongle/MTS2-0100000004", "0?blacklisted") in new stack
-- Executing [s@app-blacklist-check:2] Set("Dongle/MTS2-0100000004", "CALLED_BLACKLIST=1") in new stack
-- Executing [s@app-blacklist-check:3] Return("Dongle/MTS2-0100000004", "") in new stack
-- Executing [s@ext-did:3] Set("Dongle/MTS2-0100000004", "CDR(did)=+79255336559") in new stack
-- Executing [s@ext-did:4] ExecIf("Dongle/MTS2-0100000004", "0 ?Set(CALLERID(name)=+79032478614)") in new stack
-- Executing [s@ext-did:5] Set("Dongle/MTS2-0100000004", "CHANNEL(musicclass)=default") in new stack
-- Executing [s@ext-did:6] Set("Dongle/MTS2-0100000004", "__MOHCLASS=default") in new stack
-- Executing [s@ext-did:7] Set("Dongle/MTS2-0100000004", "__CALLINGPRES_SV=allowed_not_screened") in new stack
-- Executing [s@ext-did:8] Set("Dongle/MTS2-0100000004", "CALLERPRES()=allowed_not_screened") in new stack
-- Executing [s@ext-did:9] Goto("Dongle/MTS2-0100000004", "from-did-direct,100,1") in new stack
-- Goto (from-did-direct,100,1)
-- Executing [100@from-did-direct:1] Set("Dongle/MTS2-0100000004", "__RINGTIMER=15") in new stack
-- Executing [100@from-did-direct:2] Macro("Dongle/MTS2-0100000004", "exten-vm,novm,100,1,1,1") in new stack
-- Executing [s@macro-exten-vm:1] Macro("Dongle/MTS2-0100000004", "user-callerid,") in new stack
-- Executing [s@macro-user-callerid:1] Set("Dongle/MTS2-0100000004", "TOUCH_MONITOR=1399235106.16") in new stack
-- Executing [s@macro-user-callerid:2] Set("Dongle/MTS2-0100000004", "AMPUSER=+79032478614") in new stack
-- Executing [s@macro-user-callerid:3] GotoIf("Dongle/MTS2-0100000004", "0?report") in new stack
-- Executing [s@macro-user-callerid:4] ExecIf("Dongle/MTS2-0100000004", "1?Set(REALCALLERIDNUM=+79032478614)") in new stack
-- Executing [s@macro-user-callerid:5] Set("Dongle/MTS2-0100000004", "AMPUSER=") in new stack
-- Executing [s@macro-user-callerid:6] GotoIf("Dongle/MTS2-0100000004", "0?limit") in new stack
-- Executing [s@macro-user-callerid:7] Set("Dongle/MTS2-0100000004", "AMPUSERCIDNAME=") in new stack
-- Executing [s@macro-user-callerid:8] GotoIf("Dongle/MTS2-0100000004", "1?report") in new stack
-- Goto (macro-user-callerid,s,16)
-- Executing [s@macro-user-callerid:16] GotoIf("Dongle/MTS2-0100000004", "0?continue") in new stack
-- Executing [s@macro-user-callerid:17] ExecIf("Dongle/MTS2-0100000004", "1?Set(__CALLEE_ACCOUNCODE=)") in new stack
-- Executing [s@macro-user-callerid:18] Set("Dongle/MTS2-0100000004", "__TTL=64") in new stack
-- Executing [s@macro-user-callerid:19] GotoIf("Dongle/MTS2-0100000004", "1?continue") in new stack
-- Goto (macro-user-callerid,s,30)
-- Executing [s@macro-user-callerid:30] Set("Dongle/MTS2-0100000004", "CALLERID(number)=+79032478614") in new stack
-- Executing [s@macro-user-callerid:31] Set("Dongle/MTS2-0100000004", "CALLERID(name)=MTS2") in new stack
-- Executing [s@macro-user-callerid:32] Set("Dongle/MTS2-0100000004", "CDR(cnum)=+79032478614") in new stack
-- Executing [s@macro-user-callerid:33] Set("Dongle/MTS2-0100000004", "CDR(cnam)=MTS2") in new stack
-- Executing [s@macro-user-callerid:34] Set("Dongle/MTS2-0100000004", "CHANNEL(language)=en") in new stack
-- Executing [s@macro-exten-vm:2] Set("Dongle/MTS2-0100000004", "RingGroupMethod=none") in new stack
-- Executing [s@macro-exten-vm:3] Set("Dongle/MTS2-0100000004", "__EXTTOCALL=100") in new stack
-- Executing [s@macro-exten-vm:4] Set("Dongle/MTS2-0100000004", "__PICKUPMARK=100") in new stack
-- Executing [s@macro-exten-vm:5] Set("Dongle/MTS2-0100000004", "RT=15") in new stack
[2014-05-05 00:25:06] WARNING[5239][C-0000000c]: chan_sip.c:22046 func_header_read: This function can only be used on SIP channels.
-- Executing [s@macro-exten-vm:6] ExecIf("Dongle/MTS2-0100000004", "0?Macro(vm,novm,DIRECTDIAL,)") in new stack
-- Executing [s@macro-exten-vm:7] ExecIf("Dongle/MTS2-0100000004", "0?MacroExit()") in new stack
-- Executing [s@macro-exten-vm:8] Gosub("Dongle/MTS2-0100000004", "sub-record-check,s,1(exten,100,)") in new stack
-- Executing [s@sub-record-check:1] Set("Dongle/MTS2-0100000004", "REC_POLICY_MODE_SAVE=") in new stack
-- Executing [s@sub-record-check:2] GotoIf("Dongle/MTS2-0100000004", "1?check") in new stack
-- Goto (sub-record-check,s,7)
-- Executing [s@sub-record-check:7] Set("Dongle/MTS2-0100000004", "__MON_FMT=wav") in new stack
-- Executing [s@sub-record-check:8] GotoIf("Dongle/MTS2-0100000004", "1?next") in new stack
-- Goto (sub-record-check,s,11)
-- Executing [s@sub-record-check:11] ExecIf("Dongle/MTS2-0100000004", "0?Return()") in new stack
-- Executing [s@sub-record-check:12] ExecIf("Dongle/MTS2-0100000004", "0?Set(__REC_POLICY_MODE=)") in new stack
-- Executing [s@sub-record-check:13] GotoIf("Dongle/MTS2-0100000004", "0?exten,1") in new stack
-- Executing [s@sub-record-check:14] Set("Dongle/MTS2-0100000004", "__REC_STATUS=INITIALIZED") in new stack
-- Executing [s@sub-record-check:15] Set("Dongle/MTS2-0100000004", "NOW=1399235106") in new stack
-- Executing [s@sub-record-check:16] Set("Dongle/MTS2-0100000004", "__DAY=05") in new stack
-- Executing [s@sub-record-check:17] Set("Dongle/MTS2-0100000004", "__MONTH=05") in new stack
-- Executing [s@sub-record-check:18] Set("Dongle/MTS2-0100000004", "__YEAR=2014") in new stack
-- Executing [s@sub-record-check:19] Set("Dongle/MTS2-0100000004", "__TIMESTR=20140505-002506") in new stack
-- Executing [s@sub-record-check:20] Set("Dongle/MTS2-0100000004", "__FROMEXTEN=+79032478614") in new stack
-- Executing [s@sub-record-check:21] Set("Dongle/MTS2-0100000004", "__CALLFILENAME=exten-100-+79032478614-20140505-002506-1399235106.16") in new stack
-- Executing [s@sub-record-check:22] Goto("Dongle/MTS2-0100000004", "exten,1") in new stack
-- Goto (sub-record-check,exten,1)
-- Executing [exten@sub-record-check:1] GotoIf("Dongle/MTS2-0100000004", "0?callee") in new stack
-- Executing [exten@sub-record-check:2] Set("Dongle/MTS2-0100000004", "__REC_POLICY_MODE=never") in new stack
-- Executing [exten@sub-record-check:3] GotoIf("Dongle/MTS2-0100000004", "0?caller") in new stack
-- Executing [exten@sub-record-check:4] GotoIf("Dongle/MTS2-0100000004", "1?callee") in new stack
-- Goto (sub-record-check,exten,8)
-- Executing [exten@sub-record-check:8] GosubIf("Dongle/MTS2-0100000004", "0?record,1(exten,100,+79032478614)") in new stack
-- Executing [exten@sub-record-check:9] Return("Dongle/MTS2-0100000004", "") in new stack
-- Executing [s@macro-exten-vm:9] GotoIf("Dongle/MTS2-0100000004", "1?macrodial") in new stack
-- Goto (macro-exten-vm,s,15)
-- Executing [s@macro-exten-vm:15] GosubIf("Dongle/MTS2-0100000004", "0?clrheader,1()") in new stack
-- Executing [s@macro-exten-vm:16] Macro("Dongle/MTS2-0100000004", "dial-one,15,Ttr,100") in new stack
-- Executing [s@macro-dial-one:1] Set("Dongle/MTS2-0100000004", "DEXTEN=100") in new stack
-- Executing [s@macro-dial-one:2] Set("Dongle/MTS2-0100000004", "DIALSTATUS_CW=") in new stack
-- Executing [s@macro-dial-one:3] GosubIf("Dongle/MTS2-0100000004", "0?screen,1()") in new stack
-- Executing [s@macro-dial-one:4] GosubIf("Dongle/MTS2-0100000004", "0?cf,1()") in new stack
-- Executing [s@macro-dial-one:5] GotoIf("Dongle/MTS2-0100000004", "1?skip1") in new stack
-- Goto (macro-dial-one,s,8)
-- Executing [s@macro-dial-one:8] GotoIf("Dongle/MTS2-0100000004", "0?nodial") in new stack
-- Executing [s@macro-dial-one:9] GotoIf("Dongle/MTS2-0100000004", "0?continue") in new stack
-- Executing [s@macro-dial-one:10] Set("Dongle/MTS2-0100000004", "EXTHASCW=ENABLED") in new stack
-- Executing [s@macro-dial-one:11] GotoIf("Dongle/MTS2-0100000004", "0?next1:cwinusebusy") in new stack
-- Goto (macro-dial-one,s,23)
-- Executing [s@macro-dial-one:23] GotoIf("Dongle/MTS2-0100000004", "1?next3:continue") in new stack
-- Goto (macro-dial-one,s,24)
-- Executing [s@macro-dial-one:24] ExecIf("Dongle/MTS2-0100000004", "0?Set(DIALSTATUS_CW=BUSY)") in new stack
-- Executing [s@macro-dial-one:25] GotoIf("Dongle/MTS2-0100000004", "0?nodial") in new stack
-- Executing [s@macro-dial-one:26] GosubIf("Dongle/MTS2-0100000004", "1?dstring,1():dlocal,1()") in new stack
-- Executing [dstring@macro-dial-one:1] Set("Dongle/MTS2-0100000004", "DSTRING=") in new stack
-- Executing [dstring@macro-dial-one:2] Set("Dongle/MTS2-0100000004", "DEVICES=100") in new stack
-- Executing [dstring@macro-dial-one:3] ExecIf("Dongle/MTS2-0100000004", "0?Return()") in new stack
-- Executing [dstring@macro-dial-one:4] ExecIf("Dongle/MTS2-0100000004", "0?Set(DEVICES=00)") in new stack
-- Executing [dstring@macro-dial-one:5] Set("Dongle/MTS2-0100000004", "LOOPCNT=1") in new stack
-- Executing [dstring@macro-dial-one:6] Set("Dongle/MTS2-0100000004", "ITER=1") in new stack
-- Executing [dstring@macro-dial-one:7] Set("Dongle/MTS2-0100000004", "THISDIAL=SIP/100") in new stack
-- Executing [dstring@macro-dial-one:8] GosubIf("Dongle/MTS2-0100000004", "1?zap2dahdi,1()") in new stack
-- Executing [zap2dahdi@macro-dial-one:1] ExecIf("Dongle/MTS2-0100000004", "0?Return()") in new stack
-- Executing [zap2dahdi@macro-dial-one:2] Set("Dongle/MTS2-0100000004", "NEWDIAL=") in new stack
-- Executing [zap2dahdi@macro-dial-one:3] Set("Dongle/MTS2-0100000004", "LOOPCNT2=1") in new stack
-- Executing [zap2dahdi@macro-dial-one:4] Set("Dongle/MTS2-0100000004", "ITER2=1") in new stack
-- Executing [zap2dahdi@macro-dial-one:5] Set("Dongle/MTS2-0100000004", "THISPART2=SIP/100") in new stack
-- Executing [zap2dahdi@macro-dial-one:6] ExecIf("Dongle/MTS2-0100000004", "0?Set(THISPART2=DAHDI/100)") in new stack
-- Executing [zap2dahdi@macro-dial-one:7] Set("Dongle/MTS2-0100000004", "NEWDIAL=SIP/100&") in new stack
-- Executing [zap2dahdi@macro-dial-one:8] Set("Dongle/MTS2-0100000004", "ITER2=2") in new stack
-- Executing [zap2dahdi@macro-dial-one:9] GotoIf("Dongle/MTS2-0100000004", "0?begin2") in new stack
-- Executing [zap2dahdi@macro-dial-one:10] Set("Dongle/MTS2-0100000004", "THISDIAL=SIP/100") in new stack
-- Executing [zap2dahdi@macro-dial-one:11] Return("Dongle/MTS2-0100000004", "") in new stack
-- Executing [dstring@macro-dial-one:9] Set("Dongle/MTS2-0100000004", "DSTRING=SIP/100&") in new stack
-- Executing [dstring@macro-dial-one:10] Set("Dongle/MTS2-0100000004", "ITER=2") in new stack
-- Executing [dstring@macro-dial-one:11] GotoIf("Dongle/MTS2-0100000004", "0?begin") in new stack
-- Executing [dstring@macro-dial-one:12] Set("Dongle/MTS2-0100000004", "DSTRING=SIP/100") in new stack
-- Executing [dstring@macro-dial-one:13] Return("Dongle/MTS2-0100000004", "") in new stack
-- Executing [s@macro-dial-one:27] GotoIf("Dongle/MTS2-0100000004", "0?nodial") in new stack
-- Executing [s@macro-dial-one:28] GotoIf("Dongle/MTS2-0100000004", "0?skiptrace") in new stack
-- Executing [s@macro-dial-one:29] GosubIf("Dongle/MTS2-0100000004", "1?ctset,1():ctclear,1()") in new stack
-- Executing [ctset@macro-dial-one:1] Set("Dongle/MTS2-0100000004", "DB(CALLTRACE/100)=+79032478614") in new stack
-- Executing [ctset@macro-dial-one:2] Return("Dongle/MTS2-0100000004", "") in new stack
-- Executing [s@macro-dial-one:30] Set("Dongle/MTS2-0100000004", "D_OPTIONS=Ttr") in new stack
-- Executing [s@macro-dial-one:31] ExecIf("Dongle/MTS2-0100000004", "0?SIPAddHeader(Alert-Info: )") in new stack
-- Executing [s@macro-dial-one:32] ExecIf("Dongle/MTS2-0100000004", "0?SIPAddHeader()") in new stack
-- Executing [s@macro-dial-one:33] ExecIf("Dongle/MTS2-0100000004", "1?Set(CHANNEL(musicclass)=default)") in new stack
-- Executing [s@macro-dial-one:34] GosubIf("Dongle/MTS2-0100000004", "0?qwait,1()") in new stack
-- Executing [s@macro-dial-one:35] Set("Dongle/MTS2-0100000004", "__CWIGNORE=") in new stack
-- Executing [s@macro-dial-one:36] Set("Dongle/MTS2-0100000004", "__KEEPCID=TRUE") in new stack
-- Executing [s@macro-dial-one:37] GotoIf("Dongle/MTS2-0100000004", "0?usegoto,1") in new stack
-- Executing [s@macro-dial-one:38] GotoIf("Dongle/MTS2-0100000004", "1?godial") in new stack
-- Goto (macro-dial-one,s,43)
-- Executing [s@macro-dial-one:43] Dial("Dongle/MTS2-0100000004", "SIP/100,15,Ttr") in new stack
== Using SIP RTP TOS bits 184
> [INSERT INTO cel (eventtype,eventtime,cid_name,cid_num,cid_ani,cid_rdnis,cid_dnid,exten,context,channame,appname,appdata,amaflags,accountcode,uniqueid,linkedid,peer,userdeftype,userfield) VALUES ('CHAN_START',{ts '2014-05-05 00:25:06'},'sis','100','','','','s','from-internal','SIP/100-0000000c','','',3,'','1399235106.17','1399235106.16','','','')]
-- Called SIP/100
[2014-05-05 00:25:06] WARNING[5239][C-0000000c]: channel.c:1002 channel_indicate: [Dongle/MTS2-0100000004] Don't know how to indicate condition 22
[2014-05-05 00:25:06] WARNING[5239][C-0000000c]: channel.c:1002 channel_indicate: [Dongle/MTS2-0100000004] Don't know how to indicate condition 33
-- SIP/100-0000000c is ringing
[2014-05-05 00:25:08] WARNING[5239][C-0000000c]: channel.c:1002 channel_indicate: [Dongle/MTS2-0100000004] Don't know how to indicate condition 33
[2014-05-05 00:25:08] WARNING[5239][C-0000000c]: channel.c:1002 channel_indicate: [Dongle/MTS2-0100000004] Don't know how to indicate condition 22
-- SIP/100-0000000c answered Dongle/MTS2-0100000004
> [INSERT INTO cel (eventtype,eventtime,cid_name,cid_num,cid_ani,cid_rdnis,cid_dnid,exten,context,channame,appname,appdata,amaflags,accountcode,uniqueid,linkedid,peer,userdeftype,userfield) VALUES ('ANSWER',{ts '2014-05-05 00:25:08'},'sis','100','100','','','100','from-internal','SIP/100-0000000c','AppDial','(Outgoing Line)',3,'','1399235106.17','1399235106.16','','','')]
> [INSERT INTO cel (eventtype,eventtime,cid_name,cid_num,cid_ani,cid_rdnis,cid_dnid,exten,context,channame,appname,appdata,amaflags,accountcode,uniqueid,linkedid,peer,userdeftype,userfield) VALUES ('ANSWER',{ts '2014-05-05 00:25:08'},'MTS2','+79032478614','','','+79255336559','s','macro-dial-one','Dongle/MTS2-0100000004','Dial','SIP/100,15,Ttr',3,'','1399235106.16','1399235106.16','','','')]
> [INSERT INTO cel (eventtype,eventtime,cid_name,cid_num,cid_ani,cid_rdnis,cid_dnid,exten,context,channame,appname,appdata,amaflags,accountcode,uniqueid,linkedid,peer,userdeftype,userfield) VALUES ('BRIDGE_START',{ts '2014-05-05 00:25:08'},'MTS2','+79032478614','','','+79255336559','s','macro-dial-one','Dongle/MTS2-0100000004','Dial','SIP/100,15,Ttr',3,'','1399235106.16','1399235106.16','SIP/100-0000000c','','')]
> 0xb6d21b40 -- Probation passed - setting RTP source address to 192.168.0.2:60176
[2014-05-05 00:25:13] ERROR[5238]: chan_dongle.c:414 do_monitor_phone: [MTS2] Lost connection to Dongle
-- [MTS2] Dongle has disconnected
> [INSERT INTO cel (eventtype,eventtime,cid_name,cid_num,cid_ani,cid_rdnis,cid_dnid,exten,context,channame,appname,appdata,amaflags,accountcode,uniqueid,linkedid,peer,userdeftype,userfield) VALUES ('BRIDGE_END',{ts '2014-05-05 00:25:13'},'MTS2','+79032478614','','','+79255336559','s','macro-dial-one','Dongle/MTS2-0100000004','Dial','SIP/100,15,Ttr',3,'','1399235106.16','1399235106.16','SIP/100-0000000c','','')]
-- Executing [h@macro-dial-one:1] Macro("Dongle/MTS2-0100000004", "hangupcall,") in new stack
-- Executing [s@macro-hangupcall:1] GotoIf("Dongle/MTS2-0100000004", "1?theend") in new stack
-- Executing [s@macro-hangupcall:3] ExecIf("Dongle/MTS2-0100000004", "0?Set(CDR(recordingfile)=)") in new stack
-- Executing [s@macro-hangupcall:4] Hangup("Dongle/MTS2-0100000004", "") in new stack
== Spawn extension (macro-hangupcall, s, 4) exited non-zero on 'Dongle/MTS2-0100000004' in macro 'hangupcall'
== Spawn extension (macro-dial-one, h, 1) exited non-zero on 'Dongle/MTS2-0100000004'
> [INSERT INTO cdr (calldate,clid,src,dst,dcontext,channel,dstchannel,lastapp,lastdata,duration,billsec,disposition,amaflags,uniqueid,did,cnum,cnam) VALUES ({ ts '2014-05-05 00:25:06' },'"MTS2" <+79032478614>','+79032478614','100','from-did-direct','Dongle/MTS2-0100000004','SIP/100-0000000c','Dial','SIP/100,15,Ttr',7,5,'ANSWERED',3,'1399235106.16','+79255336559','+79032478614','MTS2')]
> [INSERT INTO cel (eventtype,eventtime,cid_name,cid_num,cid_ani,cid_rdnis,cid_dnid,exten,context,channame,appname,appdata,amaflags,accountcode,uniqueid,linkedid,peer,userdeftype,userfield) VALUES ('HANGUP',{ts '2014-05-05 00:25:13'},'sis','100','100','','','','macro-dial-one','SIP/100-0000000c','AppDial','(Outgoing Line)',3,'','1399235106.17','1399235106.16','','','')]
> [INSERT INTO cel (eventtype,eventtime,cid_name,cid_num,cid_ani,cid_rdnis,cid_dnid,exten,context,channame,appname,appdata,amaflags,accountcode,uniqueid,linkedid,peer,userdeftype,userfield) VALUES ('CHAN_END',{ts '2014-05-05 00:25:13'},'sis','100','100','','','','macro-dial-one','SIP/100-0000000c','AppDial','(Outgoing Line)',3,'','1399235106.17','1399235106.16','','','')]
== Spawn extension (macro-dial-one, s, 43) exited non-zero on 'Dongle/MTS2-0100000004' in macro 'dial-one'
== Spawn extension (macro-exten-vm, s, 16) exited non-zero on 'Dongle/MTS2-0100000004' in macro 'exten-vm'
== Spawn extension (from-did-direct, 100, 2) exited non-zero on 'Dongle/MTS2-0100000004'
> [INSERT INTO cel (eventtype,eventtime,cid_name,cid_num,cid_ani,cid_rdnis,cid_dnid,exten,context,channame,appname,appdata,amaflags,accountcode,uniqueid,linkedid,peer,userdeftype,userfield) VALUES ('HANGUP',{ts '2014-05-05 00:25:13'},'MTS2','+79032478614','','','+79255336559','100','from-did-direct','Dongle/MTS2-0100000004','','',3,'','1399235106.16','1399235106.16','','','')]
> [INSERT INTO cel (eventtype,eventtime,cid_name,cid_num,cid_ani,cid_rdnis,cid_dnid,exten,context,channame,appname,appdata,amaflags,accountcode,uniqueid,linkedid,peer,userdeftype,userfield) VALUES ('CHAN_END',{ts '2014-05-05 00:25:13'},'MTS2','+79032478614','','','+79255336559','100','from-did-direct','Dongle/MTS2-0100000004','','',3,'','1399235106.16','1399235106.16','','','')]
> [INSERT INTO cel (eventtype,eventtime,cid_name,cid_num,cid_ani,cid_rdnis,cid_dnid,exten,context,channame,appname,appdata,amaflags,accountcode,uniqueid,linkedid,peer,userdeftype,userfield) VALUES ('LINKEDID_END',{ts '2014-05-05 00:25:13'},'MTS2','+79032478614','','','+79255336559','100','from-did-direct','Dongle/MTS2-0100000004','','',3,'','1399235106.16','1399235106.16','','','')]
-- [MTS2] IMEI 351911042700560 found on data_tty=/dev/ttyUSB2 audio_tty=/dev/ttyUSB1
-- [MTS2] Trying to connect on /dev/ttyUSB2...
-- [MTS2] Dongle has connected, initializing...
[2014-05-05 00:25:19] ERROR[5275]: at_response.c:364 at_response_error: [MTS2] Getting IMSI number failed
-- [MTS2] Error initializing Dongle
-- [MTS2] Dongle initialized and ready
-- Called SIP/100
настройки # nano /etc/asterisk/dongle.conf
interval=15 ; Number of seconds between trying to connect to devices
;------------------------------ JITTER BUFFER CONFIGURATION --------------------------
;jbenable = yes ; Enables the use of a jitterbuffer on the receiving side of a
; Dongle channel. Defaults to "no". An enabled jitterbuffer will
; be used only if the sending side can create and the receiving
; side can not accept jitter. The Dongle channel can't accept jitter,
; thus an enabled jitterbuffer on the receive Dongle side will always
; be used if the sending side can create jitter.
;jbforce = no ; Forces the use of a jitterbuffer on the receive side of a Dongle
; channel. Defaults to "no".
;jbmaxsize = 200 ; Max length of the jitterbuffer in milliseconds.
;jbresyncthreshold = 1000 ; Jump in the frame timestamps over which the jitterbuffer is
; resynchronized. Useful to improve the quality of the voice, with
; big jumps in/broken timestamps, usually sent from exotic devices
; and programs. Defaults to 1000.
;jbimpl = fixed ; Jitterbuffer implementation, used on the receiving side of a Dongle
; channel. Two implementations are currently available - "fixed"
; (with size always equals to jbmaxsize) and "adaptive" (with
; variable size, actually the new jb of IAX2). Defaults to fixed.
;jbtargetextra = 40 ; This option only affects the jb when 'jbimpl = adaptive' is set.
; The option represents the number of milliseconds by which the new jitter buffer
; will pad its size. the default is 40, so without modification, the new
; jitter buffer will set its size to the jitter value plus 40 milliseconds.
; increasing this value may help if your network normally has low jitter,
; but occasionally has spikes.
;jblog = no ; Enables jitterbuffer frame logging. Defaults to "no".
[defaults]
; now you can set here any not required device settings as template
; sure you can overwrite in any [device] section this default values
; ; context for incoming calls
group=0 ; calling group
rxgain=0 ; increase the incoming volume; may be negative
txgain=0 ; increase the outgoint volume; may be negative
autodeletesms=yes ; auto delete incoming sms
resetdongle=yes ; reset dongle during initialization with ATZ command
u2diag=-1 ; set ^U2DIAG parameter on device (0 = disable everything except modem function) ; -1 not use ^U2DIAG command
usecallingpres=no ; use the caller ID presentation or not
callingpres=allowed_passed_screen ; set caller ID presentation by default use default network settings
disablesms=no ; disable of SMS reading from device when received
;from-pstn ; chan_dongle has currently a bug with SMS reception. When a SMS gets in during a
; call chan_dongle might crash. Enable this option to disable sms reception.
; default = no
language=en ; set channel default language
smsaspdu=yes ; if 'yes' send SMS in PDU mode, feature implementation incomplete and we strongly recommend say 'yes'
mindtmfgap=45 ; minimal interval from end of previews DTMF from begining of next in ms
mindtmfduration=80 ; minimal DTMF tone duration in ms
mindtmfinterval=200 ; minimal interval between ends of DTMF of same digits in ms
callwaiting=auto ; if 'yes' allow incoming calls waiting; by default use network settings
; if 'no' waiting calls just ignored
disable=no ; OBSOLETED by initstate: if 'yes' no load this device and just ignore this section
initstate=start ; specified initial state of device, must be one of 'stop' 'start' 'remote'
; 'remove' same as 'disable=yes'
exten=+79255336559 ; exten for start incoming calls, only in case of Subscriber Number not available!, also set to CALLERID(ndid)
dtmf=relax ; control of incoming DTMF detection, possible values:
; off - off DTMF tones detection, voice data passed to asterisk unaltered
; use this value for gateways or if not use DTMF for AVR or inside dialplan
; inband - do DTMF tones detection
; relax - like inband but with relaxdtmf option
; default is 'relax' by compatibility reason
; dongle required settings
[MTS1]
context=from-pstn
;audio=/dev/ttyUSB4 ; tty port for audio connection; no default value
;data=/dev/ttyUSB5 ; tty port for AT commands; no default value
imei=352216045800436
;exten=79255336559
[MTS2]
context=from-pstn
;audio=/dev/ttyUSB1 ; tty port for audio connection; no default value
;data=/dev/ttyUSB2 ; tty port for AT commands; no default value
imei=351911042700560
; or you can omit both audio and data together and use imei=123456789012345 and/or imsi=123456789012345
; imei and imsi must contain exactly 15 digits !
; imei/imsi discovery is available on Linux only
;exten=380502222222
;imei=000000000000002
;imsi=123456789012345
; if audio and data set together with imei and/or imsi audio and data has precedence
; you can use both imei and imsi together in this case exact match by imei and imsi required
[defaults]
; default = no
[MTS1]
context=from-pstn
;exten=79255336559
[MTS2]
context=from-pstn
;exten=380502222222
Или укажите где почитать стандарты я уже пробовал не получается...
Ситуация с исходящими такая же набор идет секунда вызов идет (гудки вызова) потом музыка как нет номера...
Просто их (E1550) будет еще по мимо этого 4 штуки...
