CONGESTION не отрабатывается при переадресации
gaspaarr
Сообщение gaspaarr »
Два отдельных исходящих маршрута. В обоих указаны транки сначала 1 потом 2.
Первый маршрут используется для переадресации при неответе (как misc dest указан номер телефона):
  -- Called SIP/TRUNK1-2123456/89181234567
    -- Got SIP response 503 "Service Unavailable" back from 1.2.3.4:5060
    -- SIP/TRUNK1-2123456-00000755 is circuit-busy
    -- Executing [s@macro-dialout-trunk:23] NoOp("SIP/1992-00000754", "Dial failed for some reason with DIALSTATUS = CONGESTION and HANGUPCAUSE = 34") in new stack
    -- Executing [s@macro-dialout-trunk:24] GotoIf("SIP/1992-00000754", "0?continue,1:s-CONGESTION,1") in new stack
    -- Goto (macro-dialout-trunk,s-CONGESTION,1)
    -- Executing [s-CONGESTION@macro-dialout-trunk:1] Set("SIP/1992-00000754", "RC=34") in new stack
    -- Executing [s-CONGESTION@macro-dialout-trunk:2] Goto("SIP/1992-00000754", "34,1") in new stack
    -- Goto (macro-dialout-trunk,34,1)
    -- Executing [34@macro-dialout-trunk:1] Goto("SIP/1992-00000754", "continue,1") in new stack
    -- Executing [continue@macro-dialout-trunk:1] NoOp("SIP/1992-00000754", "TRUNK Dial failed due to CONGESTION HANGUPCAUSE: 34 - failing through to other trunks") in new stack
    -- Executing [continue@macro-dialout-trunk:2] Set("SIP/1992-00000754", "CALLERID(number)=1992") in new stack
    -- Executing [89181234567@from-internal:7] Set("SIP/1992-00000754", "CALLERID(all)=") in new stack
    -- Executing [89181234567@from-internal:8] Set("SIP/1992-00000754", "_KEEPCID=TRUE") in new stack
    -- Executing [89181234567@from-internal:9] Goto("SIP/1992-00000754", "app-blackhole,zapateller,1") in new stack
    -- Goto (app-blackhole,zapateller,1)
    -- Executing [zapateller@app-blackhole:1] NoOp("SIP/1992-00000754", "Blackhole Dest: Play SIT Tone") in new stack
    -- Executing [zapateller@app-blackhole:2] Answer("SIP/1992-00000754", "") in new stack
    -- Executing [zapateller@app-blackhole:3] Zapateller("SIP/1992-00000754", "") in new stack
    -- Auto fallthrough, channel 'SIP/1992-00000754' status is 'CONGESTION'
sip*CLI>
    -- Attempting call on Local/s@tc-maint for application NoCDR() (Retry 1)
    -- Called s@tc-maint
Как мы видим, после отлупа от 1 транка, звонок уходит в блэкхол, и не пытается пойти через транк 2.
А это другой маршрут, используемый при прямом наборе, тут все работает как надо, получив отлуп от 1 транка, звонок успешно уходит через 2ой:
    -- SIP/TRUNK1-2123456-00000757 is circuit-busy
    -- Executing [s@macro-dialout-trunk:23] NoOp("SIP/1992-00000756", "Dial failed for some reason with DIALSTATUS = CONGESTION and HANGUPCAUSE = 34") in new stack
    -- Executing [s@macro-dialout-trunk:24] GotoIf("SIP/1992-00000756", "0?continue,1:s-CONGESTION,1") in new stack
    -- Executing [s-CONGESTION@macro-dialout-trunk:1] Set("SIP/1992-00000756", "RC=34") in new stack
    -- Executing [s-CONGESTION@macro-dialout-trunk:2] Goto("SIP/1992-00000756", "34,1") in new stack
    -- Executing [34@macro-dialout-trunk:1] Goto("SIP/1992-00000756", "continue,1") in new stack
    -- Executing [continue@macro-dialout-trunk:1] NoOp("SIP/1992-00000756", "TRUNK Dial failed due to CONGESTION HANGUPCAUSE: 34 - failing through to other trunks") in new stack
    -- Executing [continue@macro-dialout-trunk:2] Set("SIP/1992-00000756", "CALLERID(number)=1992") in new stack
    -- Executing [89181234567@2123456-ALL:7] Macro("SIP/1992-00000756", "dialout-trunk,3,89181234567,,off") in new stack
    -- Executing [s@macro-dialout-trunk:1] Set("SIP/1992-00000756", "DIAL_TRUNK=3") in new stack
    -- Executing [s@macro-dialout-trunk:2] GosubIf("SIP/1992-00000756", "0?sub-pincheck,s,1()") in new stack
    -- Executing [s@macro-dialout-trunk:3] GotoIf("SIP/1992-00000756", "0?disabletrunk,1") in new stack
    -- Executing [s@macro-dialout-trunk:4] Set("SIP/1992-00000756", "DIAL_NUMBER=89181234567") in new stack
    -- Executing [s@macro-dialout-trunk:5] Set("SIP/1992-00000756", "DIAL_TRUNK_OPTIONS=trL(720000:60000:29501)") in new stack
    -- Executing [s@macro-dialout-trunk:6] Set("SIP/1992-00000756", "OUTBOUND_GROUP=OUT_3") in new stack
    -- Executing [s@macro-dialout-trunk:7] GotoIf("SIP/1992-00000756", "1?nomax") in new stack
    -- Executing [s@macro-dialout-trunk:9] GotoIf("SIP/1992-00000756", "0?skipoutcid") in new stack
    -- Executing [s@macro-dialout-trunk:10] Set("SIP/1992-00000756", "DIAL_TRUNK_OPTIONS=TL(720000:60000:29500)") in new stack
    -- Executing [s@macro-dialout-trunk:11] Macro("SIP/1992-00000756", "outbound-callerid,3") in new stack
    -- Executing [s@macro-outbound-callerid:1] ExecIf("SIP/1992-00000756", "0?Set(CALLERPRES()=)") in new stack
    -- Executing [s@macro-outbound-callerid:2] ExecIf("SIP/1992-00000756", "0?Set(REALCALLERIDNUM=1992)") in new stack
    -- Executing [s@macro-outbound-callerid:3] GotoIf("SIP/1992-00000756", "1?normcid") in new stack
    -- Executing [s@macro-outbound-callerid:6] Set("SIP/1992-00000756", "USEROUTCID=") in new stack
    -- Executing [s@macro-outbound-callerid:7] Set("SIP/1992-00000756", "EMERGENCYCID=") in new stack
    -- Executing [s@macro-outbound-callerid:8] Set("SIP/1992-00000756", "TRUNKOUTCID=2123456") in new stack
    -- Executing [s@macro-outbound-callerid:9] GotoIf("SIP/1992-00000756", "1?trunkcid") in new stack
    -- Goto (macro-outbound-callerid,s,14)
    -- Executing [s@macro-outbound-callerid:14] ExecIf("SIP/1992-00000756", "1?Set(CALLERID(all)=2123456)") in new stack
    -- Executing [s@macro-outbound-callerid:15] ExecIf("SIP/1992-00000756", "0?Set(CALLERID(all)=)") in new stack
    -- Executing [s@macro-outbound-callerid:16] ExecIf("SIP/1992-00000756", "1?Set(CALLERID(all)=2123456)") in new stack
    -- Executing [s@macro-outbound-callerid:17] ExecIf("SIP/1992-00000756", "0?Set(CALLERPRES()=prohib_passed_screen)") in new stack
    -- Executing [s@macro-outbound-callerid:18] Set("SIP/1992-00000756", "CDR(outbound_cnum)=2123456") in new stack
    -- Executing [s@macro-outbound-callerid:19] Set("SIP/1992-00000756", "CDR(outbound_cnam)=") in new stack
[2015-01-22 00:21:39] WARNING[28305]: func_cdr.c:349 cdr_write_callback: CDR requires a value (CDR(variable)=value)
    -- Executing [s@macro-dialout-trunk:12] GosubIf("SIP/1992-00000756", "0?sub-flp-3,s,1()") in new stack
    -- Executing [s@macro-dialout-trunk:13] Set("SIP/1992-00000756", "OUTNUM=89181234567") in new stack
    -- Executing [s@macro-dialout-trunk:14] Set("SIP/1992-00000756", "custom=SIP/TRUNK2-2123456") in new stack
    -- Executing [s@macro-dialout-trunk:15] ExecIf("SIP/1992-00000756", "0?Set(DIAL_TRUNK_OPTIONS=M(setmusic^default)TL(720000:60000:29500))") in new stack
    -- Executing [s@macro-dialout-trunk:16] ExecIf("SIP/1992-00000756", "0?Set(DIAL_TRUNK_OPTIONS=TL(720000:60000:29500)M(confirm))") in new stack
    -- Executing [s@macro-dialout-trunk:17] Macro("SIP/1992-00000756", "dialout-trunk-predial-hook,") in new stack
    -- Executing [s@macro-dialout-trunk-predial-hook:1] MacroExit("SIP/1992-00000756", "") in new stack
    -- Executing [s@macro-dialout-trunk:18] GotoIf("SIP/1992-00000756", "0?bypass,1") in new stack
    -- Executing [s@macro-dialout-trunk:19] ExecIf("SIP/1992-00000756", "1?Set(CONNECTEDLINE(num,i)=89181234567)") in new stack
    -- Executing [s@macro-dialout-trunk:20] ExecIf("SIP/1992-00000756", "1?Set(CONNECTEDLINE(name,i)=CID:2123456)") in new stack
    -- Executing [s@macro-dialout-trunk:21] GotoIf("SIP/1992-00000756", "0?customtrunk") in new stack
    -- Executing [s@macro-dialout-trunk:22] Dial("SIP/1992-00000756", "SIP/TRUNK2-2123456/89181234567,300,TL(720000:60000:29500)") in new stack
  == Using SIP RTP TOS bits 184
    -- Called SIP/TRUNK2-2123456/89181234567
    -- SIP/TRUNK2-2123456-00000758 is making progress passing it to SIP/1992-00000756
  == Spawn extension (macro-dialout-trunk, s, 22) exited non-zero on 'SIP/1992-00000756' in macro 'dialout-trunk'
  == Spawn extension (2123456-ALL, 89181234567, 7) exited non-zero on 'SIP/1992-00000756'
    -- Executing [h@2123456-ALL:1] Macro("SIP/1992-00000756", "hangupcall,") in new stack
    -- Executing [s@macro-hangupcall:1] GotoIf("SIP/1992-00000756", "1?theend") in new stack
    -- Executing [s@macro-hangupcall:3] ExecIf("SIP/1992-00000756", "0?Set(CDR(recordingfile)=)") in new stack
    -- Executing [s@macro-hangupcall:4] Hangup("SIP/1992-00000756", "") in new stack
  == Spawn extension (macro-hangupcall, s, 4) exited non-zero on 'SIP/1992-00000756' in macro 'hangupcall'
  == Spawn extension (2123456-ALL, h, 1) exited non-zero on 'SIP/1992-00000756'
Баг или так и должно быть?
Re: CONGESTION не отрабатывается при переадресации
Как настроили - так и работает. Нет никакого бага.
gaspaarr
Настроили все верно, очередной баг астериска...
Если в исходящем маршруте стоит условие -- CID вида 1XX, а Extension с которого осуществляется вызов имеет ext номер 1119 но в CID Num Alias подставлено 111, то вызов обрабатывается только первым транком, потом уходит в блэкхол. При этом система правильно трактует CID Num Alias, просто на каком-то этапе, когда надо передать вызов на второй транк, система смотрит не на CID Num Alias, а на Ext num и соответственно заруливает вызов в блэкхол, т.к. для такого CID у нее нет маршрута.
Причем тут asterisk ? Речь идет о Freepbx . А то , что усложняете Вы себе жизнь странными схемами - это проблема не фрейморка.
gaspaarr
Согласен, с алиасами неоднозначная ситуация, теперь те же грабли с внешними входящими звонками, теперь вообще не ясно, кто виноват, * или freepbx.
В маршруте прописано:
exten => _*8[89]XXXXXXXXX/_XXX.
Поступает входящий с 74951234567, его переадресуем через misc dest на внешний номер, и такая же проблема, звонок обрабатывается только первым транком, там "занято" и все, блэкхол.
Если убираю _XXX. в маршруте, то вызов переходит на второй транк.
На каком уровне дэбага можно увидеть процесс обработки CID в маршруте?
Все расскажет команда
dialplan show <набираемый_номер>@from-internal
А уровень дебага тут ни при чем , так как это не дебаг , а обычное логгирование.
В вашем маршруте идет переадресация с внутреннего интерфейса. Почему Вы решили , что звонок должен подходить под шаблон _XXX. ?
gaspaarr
Так по dialplan show все именно так, как и должно быть (CID, транки)... вопрос в том, чтобы понять, когда вызов не проходит по первому транку, какой caller id обрабатывается в системе, раз он не попадает во второй транк.
gaspaarr
Обновил модули freepbx, поменял 13 ядро на 11... этот глюк не ушел
чтобы понять, когда вызов не проходит по первому транку, какой caller id обрабатывается в системе - добавьте строки NoOp(Caller ID is {CALLERID(all)}) во все места, где обрабатывается этот вызов.
gaspaarr
ну да... все так и есть,
вот первая попытка:
"Caller ID first try is "89101234567" <89101234567> 89101234567") in new stack
а вот это вторая попытка, после того как первый транк отказался выполнять вызов:
"Caller ID second try is "" <> ") in new stack
и все таки, это баг астериска или freepbx?
