Asterisk и протей, 484 Address Incomplete.
Kasper_WPS
Сообщение Kasper_WPS »
Прошу посмотреть debug-log SIP при исходящем:
-- Executing [2111@phones:1] NoOp("SIP/134-00000217", "") in new stack
-- Executing [2111@phones:2] Dial("SIP/134-00000217", "SIP/prov/2111,30") in new stack
Audio is at 14776
Reliably Transmitting (NAT) to 10.10.2.9:5060:
INVITE sip:2111@10.10.2.9 SIP/2.0
Via: SIP/2.0/UDP 10.10.1.4:5060;branch=z9hG4bK08de6eea;rport
To: <sip:2111@10.10.2.9>
Contact: <sip:74737@10.10.1.4:5060>
Call-ID: 752fe4912d6413525c17ec6a241ce462@10.10.1.4:5060
CSeq: 102 INVITE
User-Agent: Asterisk PBX 11.15.0
Date: Thu, 16 Apr 2015 13:33:11 GMT
Content-Length: 178
v=0
o=root 1262582010 1262582010 IN IP4 10.10.1.4
s=Asterisk PBX 11.15.0
c=IN IP4 10.10.1.4
t=0 0
m=audio 14776 RTP/AVP 8
a=rtpmap:8 PCMA/8000
a=ptime:20
a=sendrecv
-- Called SIP/med.cap.ru/2111
<--- SIP read from UDP:10.10.2.9:5060 --->
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.10.1.4:5060;received=10.10.10.5;branch=z9hG4bK08de6eea;rport=5060
To: <sip:2111@10.10.2.9>;tag=142919495100014862
Contact: <sip:2111@10.10.2.9:5060>
CSeq: 102 INVITE
--- (8 headers 0 lines) ---
SIP/2.0 484 Address Incomplete
CSeq: 102 INVITE
Reason: Q.850;cause=28
-- Got SIP response 484 "Address Incomplete" back from 10.10.2.9:5060
ACK sip:2111@10.10.2.9 SIP/2.0
CSeq: 102 ACK
-- Executing [2111@phones:3] Hangup("SIP/134-00000217", "") in new stack
== Spawn extension (phones, 2111, 3) exited non-zero on 'SIP/134-00000217'
Scheduling destruction of SIP dialog '8c6e72ca-9123d61b@192.168.3.3' in 32000 ms (Method: INVITE)
<--- Reliably Transmitting (no NAT) to 172.20.48.165:5260 --->
SIP/2.0 484 Address incomplete
Via: SIP/2.0/UDP 172.20.48.165:5260;branch=z9hG4bK-915b11bf;received=172.20.48.165
From: "134" <sip:134@10.10.1.4>;tag=d100e2fe970f0377o0
To: <sip:2111@10.10.1.4>;tag=as0d09aea7
Call-ID: 8c6e72ca-9123d61b@192.168.3.3
CSeq: 102 INVITE
Server: Asterisk PBX 11.15.0
Какие ошибки в протоколе? На той стороне (у оператора) номер 2111 зарегистрирован. Оператор ничего сказать не может дополнительно, к сожалению.
Re: Asterisk и протей, 484 Address Incomplete.
в протоколе ошибок нет
это проблема вас и вашего оператора
Kasper_WPS
Что возможно сделать в данном случае? На что обратить внимание?
обратите внимание на бездействие вашего оператора
Kasper_WPS
Невозможно. Вышестоящая организация. Они правы по-умолчанию...
Платный суппорт.
Платный суппорт.
Там явно вояки)
Тогда двойной тариф, + надбавка за упёртость.
или медики
Kasper_WPS писал(а):Called SIP/med.cap.ru/2111
Там явно видимая ерунда с адресацией:
что можно понимать как внутренний абонент SIP/134 звонит на 2111 через пронырливого вайдера (сокр. - про-вайдера)
но в пакетах уже 134 превратилось в CIDname, а абонент уже стал SIP/74737
это у него на пире, которым описан провайдер, галиматься стоит, типа defaultuser=74737 или fromuser=74737.
