Ошибки после обновления
M1chA
Сообщение M1chA »
Всем привет!
Такая проблема.
Обновил FreePBX c 12 на 13 и в логах посыпались ошибки...
Подскажите пожалуйста как их решить.
Список ошибок:
  • [2016-02-03 11:50:53] ERROR[1333] json.c: Error building JSON from '{s: s, s: s}': Invalid UTF-8 string.
    [2016-02-03 11:50:53] ERROR[1333] stasis_channels.c: Error creating message
    [2016-02-03 11:50:53] ERROR[1333] config_options.c: Unable to load config file 'acl.conf'
    [2016-02-03 11:50:54] ERROR[1333] config_options.c: Unable to load config file 'cel.conf'
    [2016-02-03 11:50:54] ERROR[1333] sounds_index.c: Failed to stat /var/lib/asterisk/sounds/exited-vm-will-be-transfered.sln
    [2016-02-03 11:50:54] ERROR[1333] sounds_index.c: Failed to stat /var/lib/asterisk/sounds/agent-logoff.sln
    [2016-02-03 11:50:54] ERROR[1333] sounds_index.c: Failed to stat /var/lib/asterisk/sounds/you-will-be-transfered-menu.sln
    [2016-02-03 11:50:54] ERROR[1333] sounds_index.c: Failed to stat /var/lib/asterisk/sounds/incoming-call-1-accept-2-decline.sln
    [2016-02-03 11:50:54] ERROR[1333] sounds_index.c: Failed to stat /var/lib/asterisk/sounds/incoming-call-no-longer-avail.sln
    [2016-02-03 11:50:54] ERROR[1333] sounds_index.c: Failed to stat /var/lib/asterisk/sounds/please-enter-your-extension-then-press-pound.sln
    [2016-02-03 11:50:54] ERROR[1333] sounds_index.c: Failed to stat /var/lib/asterisk/sounds/line-busy-transfer-menu.sln
    [2016-02-03 11:50:54] ERROR[1333] sounds_index.c: Failed to stat /var/lib/asterisk/sounds/featurecode.sln
    [2016-02-03 11:50:54] ERROR[1333] sounds_index.c: Failed to stat /var/lib/asterisk/sounds/agent-login.sln
    [2016-02-03 11:50:54] ERROR[1333] config_options.c: Unable to load config file 'statsd.conf'
    [2016-02-03 11:50:55] ERROR[1333] res_pjsip_config_wizard.c: Unable to load config file 'pjsip_wizard.conf'
    [2016-02-03 11:50:55] ERROR[1333] res_pjsip/config_transport.c: Transport '127.0.0.1-udp' could not be started: Address already in use
    [2016-02-03 11:50:55] ERROR[1333] res_sorcery_config.c: Could not create an object of type 'transport' with id '127.0.0.1-udp' from configuration file 'pjsip.conf'
    [2016-02-03 11:50:55] ERROR[1333] res_pjsip/config_transport.c: Transport '10.163.4.203-udp' could not be started: Address already in use
    [2016-02-03 11:50:55] ERROR[1333] res_sorcery_config.c: Could not create an object of type 'transport' with id '10.163.4.203-udp' from configuration file 'pjsip.conf'
    [2016-02-03 11:50:55] ERROR[1333] res_phoneprov.c: Unable to load config phoneprov.conf
    [2016-02-03 11:50:55] ERROR[1333] res_phoneprov.c: Unable to load provisioning profiles.
    [2016-02-03 11:50:56] ERROR[1333] config_options.c: Unable to load config file 'xmpp.conf'
    [2016-02-03 11:50:56] ERROR[1333] config_options.c: Unable to load config file 'hep.conf'
    [2016-02-03 11:50:56] ERROR[1333] res_calendar.c: Unable to load config calendar.conf
    [2016-02-03 11:50:56] ERROR[1333] config_options.c: Unable to load config file 'res_parking.conf'
    [2016-02-03 11:50:56] ERROR[1333] res_config_sqlite3.c: Missing config file 'res_config_sqlite3.conf'
    [2016-02-03 11:50:56] ERROR[1333] res_config_ldap.c: Cannot load configuration file: res_ldap.conf
    [2016-02-03 11:50:56] ERROR[1333] res_config_ldap.c: Cannot load LDAP RealTime driver.
    [2016-02-03 11:50:56] ERROR[1333] config_options.c: Unable to load config file 'motif.conf'
    [2016-02-03 11:50:56] ERROR[1333] chan_motif.c: Unable to read config file motif.conf. Module loaded but not running.
    [2016-02-03 11:50:56] ERROR[1333] chan_dahdi.c: Unable to load config chan_dahdi.conf
    [2016-02-03 11:50:56] ERROR[1333] chan_ooh323.c: Can't load ooh323 config file, OOH323 Disabled
Re: Ошибки после обновления
а зачем обновили ?
просто нету таких файлов phoneprov.conf - создайте
M1chA
Сообщение M1chA »
Обновил, потому, что в версии 13 возможна запись приветствия в браузере а в 12 такого нет.
Т.е, если я правильно понял в /etc/asterisk/ мне нужно создать файлы на которые ругается астер?
Не просто создать, а их контент - тоже.
Хорошо бы Вам документацию почитать! Где всё это описано. А в сорцах 13 версии есть и примеры всех этих файлов. А в них - комментарии - что значат опции.
M1chA
Сообщение M1chA »
Ткните пожалуйста носом в доки,уважаемый ded. Заранее премного благодарен.
Первая (!) ссылка в Гугле
https://wiki.asterisk.org/wiki/display/ ... sterisk+13
