username mismatch, have <one>, digest has <two>
shader
Сообщение shader »
Бред какой-то...
Хочу на asterisk 13 зарегистрировать пользователя с username отличным от номера телефона.
номер - 113, username diacom.
В итоге получаю:
<--- SIP read from UDP:192.168.10.245:5070 --->
REGISTER sip:192.168.10.5:5080 SIP/2.0
Via: SIP/2.0/UDP 192.168.10.245:5070;branch=z9hG4bK639256993029711520;rport
From: 113 <sip:113@192.168.10.5:5080>;tag=254378274
To: 113 <sip:113@192.168.10.5:5080>
Call-ID: 20842835110212-20056257226014@192.168.10.245
CSeq: 1 REGISTER
Contact: <sip:113@192.168.10.245:5070>
Expires: 60
User-Agent: Voip Phone 1.0
--- (11 headers 0 lines) ---
Sending to 192.168.10.245:5070 (no NAT)
<--- Transmitting (NAT) to 192.168.10.245:5070 --->
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 192.168.10.245:5070;branch=z9hG4bK639256993029711520;received=192.168.10.245;rport=5070
To: 113 <sip:113@192.168.10.5:5080>;tag=as3b01ca56
CSeq: 1 REGISTER
Server: Asterisk PBX 14.2.1
WWW-Authenticate: Digest algorithm=MD5, realm="vesta", nonce="273e9b2f"
Scheduling destruction of SIP dialog '20842835110212-20056257226014@192.168.10.245' in 32000 ms (Method: REGISTER)
Via: SIP/2.0/UDP 192.168.10.245:5070;branch=z9hG4bK25502311732838831140;rport
CSeq: 2 REGISTER
Authorization: Digest username="diacom", realm="vesta", nonce="273e9b2f", uri="sip:192.168.10.5:5080", response="95adc8381eae5cb8e53bbfab0c4ab87d", algorithm=MD5
Expires: 60
т. е. идёт нормальны процесс регистрации, а потом
--- (12 headers 0 lines) ---
[Jun 21 16:02:38] WARNING[20413]: chan_sip.c:17169 check_auth: username mismatch, have <113>, digest has <diacom>
SIP/2.0 403 Forbidden
Via: SIP/2.0/UDP 192.168.10.245:5070;branch=z9hG4bK25502311732838831140;received=192.168.10.245;rport=5070
CSeq: 2 REGISTER
[Jun 21 16:02:38] NOTICE[20413]: chan_sip.c:28536 handle_request_register: Registration from '113 <sip:113@192.168.10.5:5080>' failed for '192.168.10.245:5070' - Username/auth name mismatch
Естественно, я указыват в настройках пира:
defaultuser = diacom
fromuser = diacom
username = diacom (ругается на depricated)
В общем, чтобы я не делал, всегда упираюсь в эту строку:
что не так? asterisk не умеет различать username от номера телефона?
при этом:
sip show peer 113
 * Name       : 113
  Description  :
  Secret       : <Set>
  FromUser     : diacom
  Def. Username: diacom
Re: username mismatch, have <one>, digest has <two>
Параметры
FromUser : diacom служат для исходящих, а не для регистрации.
Если Вы сделаете пир вида
[diacom]
type=user
secret=mysecret
context=from-internal
то пакет Register от софтфона должен выглядеть как
и скорее всего он зарегистрируется.
И в extensions.conf
exten => 113,1,Dial(SIP/diacom)
то всё будет ровно так, как захотелось.
shader
Сообщение shader »
Похоже, такая схема меня не спасёт. В общем, ситауция такая: есть старая циска:
IAD2400 Series.(24 поортовый voip шлюз) В настройках её useragent'a можно создать только одну регистрацию, указав username и password.
При этом, она шлёт пакеты регистрации именно так как я указал в первом посте: в качестве name используя номера телефонов, созданных на pts портах абонентов, а в качестве username (при digest аутентификации), ту самую настройку из sip-ua, или говоря по другому, в поле from всегда будет номера телефонов. Если asterisk не поддерживает раздельную регистрацию, значит нужно придумывать что-то другое... Пойду думать :)
==Add later===
В общем, разрулил, оставив транк без регистрации и некрасиво обойдя NAT.
Надо было регистрировать IAD24 не как транк (как Вы описывали), а указать на voip портах опцию register e164, и тогда бы каждый порт регистрировался своим внутренним номером. Но 24 регистрации с одного ИП адреса - логически некрасиво. Поэтому просто транк без регистрации - вполне себе нормальное решение. Прописать статический SIP пир IAD24 и отправлять вызовы на него
Dial(SIP/IAD24/${EXTEN}) типа - он сам разруливает в себе на какой порт идёт вызов. Что, собственно, Вы и сделали.
shader
Сообщение shader »
а как реализовать то же самое, но если peer (в данном случае IAD) находится за NAT? Я так понимаю, только регистрация последней с qualify yes для поддержания соединения за NAT, верно?
gosha
Сообщение gosha »
sip.conf
match_auth_username=yes
shader писал(а):а как реализовать то же самое, но если peer (в данном случае IAD) находится за NAT? Я так понимаю, только регистрация последней с qualify yes для поддержания соединения за NAT, верно?
Можно и без регистрации. Сделать проброс сигнального порта и медиа портов. Но держать 24 телефона в другом подразделении за NAT идеологически неверно, лучше построить VPN и избавиться таким образом от NAT.
shader
Сообщение shader »
gosha писал(а):sip.conf
пробовал конечно. Не помогает. Похоже, эта опция не для этого. и yes и no ставил. Перечитал весь sip.conf.example
shader
Сообщение shader »
Я так и думал. Спасибо.
